Question about Pool & Spa
The Pump-Trap lid is stuck. What is the best tool to open the plastic lid 16920-11 of the 6[in] trap of the Sta Rite max-e-glas pump?
john224
  • 1378 Answers
SOURCE: I have a sta rite dura glas 1HP pump and can't
Lock the shaft at the end where you electrical connections are made (disconnected of course!) and spin it off counterclockwise.
Posted on Aug 11, 2009
  • 3600 Answers
SOURCE: Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Posted on Sep 29, 2009
john224
  • 1378 Answers
SOURCE: I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Posted on Jan 04, 2010
  • 15371 Answers
SOURCE: Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Posted on Apr 03, 2010
Coastsider
  • 331 Answers
SOURCE: need manual on cleaing sta rite systems filter
http://www.pentairpool.com/pdfs/System3SMOM.pdf
Posted on Apr 14, 2010
Sta rite dyna glas 1 hp pool pump low water pressure
There are a few questions you need to address first. One is the pump sucking are 2/ is the skimmer box at the pool full of leaf matter 3/ I have the pump impeller got leaf of rubbish in it. Check these items first.
Jul 05, 2014 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
I have a Sta-Rite Max-E-Pro centrifugal pump with integral trap that was installed march 17, 2011. Yesterday, the pump began making a noise. Called pool co, they came out and said bearings were burned...
yes and no, the motor might be rebuilt about $75 . you need to know how many gallons your pool is, screened in or solar heat and ask your local pool pump motor repair guy with free testing, if you have the right size pump for your pool, if so can the motor be repaired. jay
Dec 04, 2012 | Sta Rite Pool & Spa
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
The motor is running OK, but it won't pump the water
a suction leak will cause the pump not to prime... check the lid gasket, lid for cracks,pipes and valves. you can rap the fittings with electrical tape, to help you locate leaks.. a shaft seal is a good start, this will allow you to ree the condition of the impeller . it may be plugged, also see if there is cracks in the hair basket it will allow trash to get into the impeller
Mar 22, 2011 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Need bearing within PN C103-137P1 , higher assembly would be P2PA50-120L
most of these are 6203 2rs c3 bearings used in this motor. here is a picture on how to remove your pump for service, i would suggest professional repair to avoid extra costs.. just search your area for yoour local pool pump motor repair guy..remember to prime the pump after any pump repair ..jay
Sep 21, 2010 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Sta-rite problem
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Pool & Spa Logo
77 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
