How to program a am 7 automate remote 474a
Need help programing my remote to my car alarm
    New Friend:
I purchased a automate 474K remote from Autozone and the instructions were to find a single button under the dash and set the new remote to the old settings. There is no single button, as far as I can see. But there is a large 2 x 3" wiring block where the antenae wire plugs into. There are many other wires also plugged into this "Automate" block. But no button.
What do I do ?
Posted on Jul 16, 2013
3 Suggested Answers
  • 4 Answers
SOURCE: i need help programming my rcr3273 universal remote
Go to www.retrevo.com I found both the manual and the code booklet for my RCA rcr311w remote. you must register your email and it is in Adobe PDF form but its easy and free
Posted on Dec 28, 2008
Calvinrueb87
  • 38 Answers
SOURCE: RCA Universal Remote Model #rcr311w
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Posted on Jan 11, 2009
When I changed the car battery it will not start it turns over how do I reset a automate alarm
Looks like 2 questions in one here.... The lack of start is likely to be one of 2 things.
1 your battery terminals connectors are dirty or loose so you are not getting a good connection...take them off, use a dry sponge scoured to clean the connection surfaces on battery and inside surface of the connector.. Clean the threads on the tightening bolt too, so you can clamp it tight.. Reconnect using the right size spanner so it does not round off .
2 you may have tried to save money by buying the wrong battery....a4x4 pickup truck won't start using a battery designed for a Smart car..you need to check the Cold Crank Amps capability of the battery.... The bigger the vehicle, the higher that has to be... It does no harm to buy a battery with a higher CCA... If you can afford it.... Because the battery is stronger so starting is much easier on it...so it lasts longer if maintained.
3 to reset an automatic alarm, you either haveI', follow these steps...
Instructions
Place your key in your car's ignition and turn the key to the "On" position.
Press and hold the "Program" switch on your car's alarm transmitter. (Google to find where that is on your model)
Press any button on your car remote while you are holding the "Program" switch and release both buttons.
Press the "Program" switch on the alarm's transmitter once more and release it.
5
Remove the key from the ignition and press a button on your remote control to see if the programming worked.
Mar 03, 2015 | Cars & Trucks
I just bought a Cherokee and it had this rpn 487/v/p/x remote in the glove box. how do I program this?
1 Put your key in the ignition and turn it to the on position.
2 Press and hold the "program" switch on your Jeep's alarm transmitter.
3 Press any button on the car remote and hold down the "program" switch.
4 Now release both buttons.
5 Press the "program" switch on the Jeep's alarm transmitter one more time and let go of it.
6 Now take the key out of the ignition.
7 Try pressing a button on the remote control to see if it worked.
Nov 14, 2014 | Cars & Trucks
How to program a AM7 AUTOMATE REMOTE 474A
please read your owner manual , if you do not have please download it
for free. go to
www.fitness.manualsonline.com or www manualslib.com
God bless you
Nov 29, 2012 | Televison & Video
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Someone programmed their remote into my Bulldog 2010 alarm brain and is deactivating my alarm and then vandalizing my car. How do I get rid of their programming instructions and neutralize their remote?
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Dec 17, 2009 | Basic Remote Vehicle Alarm System
Need to pair the remote with the alarm on a DEI Python 990 car alarm
If you know where your Valet switch is, turn the ignition on, push and release the valet switch once, then push and hold it, you should hear the siren chirp once, then while still holding the valet switch, push the #1 button on the remote, you should hear the siren chirp again. it is now programed. If you have the package that came with the remote, it should have a table on the back that tells you how many pushes of the valet for which feature you want to program. Most remotes are one push for all features, some are 7 or 8 pushes. So if it say auto learn is 7, turn the key on, push it 7 times, the push it again and hold it, the push #1 button, and it's programed. Hope this helps. If all else fails, take it to your nearest best buy, if they charge you to program it, it won't be much.
Aug 20, 2009 | Vehicle Parts & Accessories
REMOTE DOOR LOCK 1997 ES 300 LEXUS
Even if the remote is fairly new they can lose their programming you may have to have it re-programed
Mar 17, 2009 | 1997 Lexus ES 300
Televison & Video Logo
863 people viewed this question
Top Televison & Video Experts
