Question about Craftsman Saws
Users manual for 720-32708
8" adjustable dado blades
3 Suggested Answers
  • 22 Answers
SOURCE: bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Posted on Dec 13, 2008
rowdy45176
  • 2176 Answers
SOURCE: I need an instruction manual
you might try Dewaltservicenet.com and type in your model number in the middle of the page under need manual and see if you can find it there if not let me know and I will try and find one for you.
Posted on Dec 08, 2009
Cuts unevenly
This is probably because the offsetting tapered discs in the dado are not lined up to compliment each other and your dado is tipping more to one side than the other - if the blade was tipping to the left and right the same amount, both sides would cut to the same depth and the deepest part would be right in the middle. In an extreme case, if the blade tipped only to the right and not to the left, then the left side would cut the deepest and the bottom of the cut would curve up (shallower) to the right.
The same effect could be due to your arbor not being set exactly at 0 or 90 degrees. The angle indicator on the saw is usually not very accurate. Put a regular blade in, raise it up all of the way, then check for squareness between the table and the side of the blade (using a known good square). Adjust the tilt until you are good, then put the adjustable dado back in.
Sep 04, 2012 | Oldham 7005012 7 Inch Adjustable Dado...
How do I set the dado width?
Dado blades come in sets with two side blades and a series of center blades to widen the cut. The no of blades put in the center sets the inital cut, and a series of these cuts can widen the cut farther. The poor mans dado can be done by a series of single saw cuts (kerfs) across a measured distance, moving the fence a small amount each time and then taking a chisel and working the waste out of the slot. For a primer on Dados, see: http://www.newwoodworker.com/hottodado.html
Jan 10, 2011 | Craftsman Garden
I bought a craftsman dado blade set but can't find the instructions and I have no idea how to use it. Is it possible to get instructions
Dado blades are used in a variety of saw applications. Commonly tables saws. The manual for your table saw should identify if the saw is capable of using this blade-set Never used dado blades in a saw that is not intended for them as this can result in severe injury to yourself and or damge to the tool. If your are unsure if your saw can accomodate dado blade please post your make and model of saw and someone will try to help you.
Dec 29, 2010 | Craftsman Garden
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
Jun 29, 2010 | Hitachi C10FR 10" Job-Site Table Saw 15...
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Mar 28, 2010 | Craftsman 10" Table Saw
Can I use a dado blade on my craftsman tablesaw model 137. 248830 if so what kind/size?
yes you can and here is a nice online manual that is free and you can even print out if you like
http://dl.owneriq.net/e/e99c86ed-3ba5-4bb5-a567-3b4fffebfc1f.pdf
it will show you all of the saws usues and attachments including dado
Sep 25, 2009 | Craftsman Saws
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
I bought a Dado blade set dd208 and there are no instructions
I'm hesitant to even answer, not knowing your skill level. But understanding that you will probably have a use for an item you purchased, and use it one way or another, here's a primer...
Be careful! Never push your hand directly toward the rotating saw such that if the workpiece kicks back your momentum will carry your hand into the blade. Begin by raising the blade only a little above the table surface and run a pass with clean wood over it to get the feel of the resistance a stack of dado blades gives. Consider making a groove in two or more passes if you need to raise the blade more than 1/4" to cut it in a single pass. Use metal dado shims to adjust the precise width of cut. Tighten the stack in a balanced way, such that the carbide teeth are not in contact with one another. Stay away from wobble dado sets. Etc. Etc. Etc.
You may wish to have a look at this website, whose author has obviously given the subject considerable thought: http://www.newwoodworker.com/usngstkddados.html
Finally, be carefull. If you think a single saw blade can tear flesh, imagine what a 3/4" wide swath will do to your hand. Think about your setups. Use test pieces to get them right. Then pay attention while you run your dados. And try to avoid plunge cuts, especially on anything shorter than a couple of feet in length. When you can, use a miter jig in the slot to hold any work you have to pass cross-grain over the dado.
Be careful, feed smoothly, and hold your workpiece firmly against the fence while it passes over the blade.
Nov 29, 2008 | Saws
Bosh 4000 table saw , using dado blades.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Saws Logo
357 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
