Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai pdp4298 42 in. plasma
When I plug the power cord in it makes a clicking noise in the back of the set. there is no picture and it continues to make this sound until you unplug it.it sounds as if the tv is continually turning on and off. can anyone offer any suggestions
  • littlered987 May 28, 2008
    I have the same problem. I have an Akai pdp4294 plasma display, and it makes a clicking noise when I plug it in, every couple of seconds until I unplug it. Neither the sound or picture come on, just the clicking noise. Any suggestions would be excellent! Can someone help us??
  • 20 Answers
May be the power board check for shorted q 14 and f9 in power board
Posted on Aug 17, 2009
    Champion:
  • 217 Answers
The clicking sound is the relay switch on the power board, it could be the power board or the logic board
Posted on Feb 18, 2007
Why does my TV turn on and off by itself continuously when plugged in? (The remote is not being activated)
Hello, there are several things that it could be, but if the set comes on with a picture even for a couple of seconds, I would bet it's the main board failing. Part # is EBT48854401.....thanks
Apr 24, 2017 | LG 50PG20 50 in. Plasma HDTV
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
Akai PDP4204 has no picture. When its plugged in a flashes 5 red lights. Someone told me its the power supply i have checked some of the things that people say go bad on fix ya. I also was checking the...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 09, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
My akai tv model lct3785ta will not turn on
Ok.. What is the status of the power LED at the front. Does it blink, change color a few seconds after its turned on? Do you notice any clicking noise from the set?
Please provide this info so that we can continue with the diagnosis.
Sai.
Jan 25, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Tv just makes clicking noise and doesn't turn on
I had the same problem. The power board for the on-off had to be replaced. The set is only 11 months old.
Oct 19, 2009 | Philips 42PFP5332D 42 in. Plasma...
Buzzing Noise
It really sounds like your power supply is having problems with heat and not enough cooling inside your tv. You should if you can take the back cover off, also, and blow out all the lint and dust that has been drawn into the tv over time. Usually a couple of years is enough to build up dust and lint that can cause tiny static discharges inside your set. If there is a way of keeping your set cooler by placing it in a different position where there is sufficient room for air to circulate without restriction around it, that would help as well. The power supply the one with the power cord going to it from the inside should be your culprit. Good luck and God bless.
Jan 08, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Can't get anything on the screen
Unplug the power cord from the TV set and leave it unplugged for 5 minutes. Plug the power cord back into the TV and turn it on. It should work. This is not an uncommon problem for the Akai line.
Nov 02, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Samsung plasma
just to be sure, plug something else into the same wall socket to make sure you have power there. If you have power at the wall and the TV has a detachable power cord, try the TV power cord in your computer to see if it works. Otherwise you probably have a faulty power supply in the TV.
Aug 17, 2008 | Samsung LN-S4051D 40 in. LCD Television
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
452 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
