Question about GE XL1800 1100 Watts Microwave Oven
Did I blow it up????
I put a potato in the microwave and did not realize that the end of the potato had been cut...bottom line I overcooked the potato, causing smoke and a small fire which I put out promptly. Now nothing works - the lights won't come on. Ichecked the fuse box and all is OK there. Should I just buy a new microwave?
  • 108 Answers
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Posted on Nov 16, 2008
Samsung microwave ME21K7010DS displays C-10 when I select potato. Stats working but after about 2 min message C-10 appears. Works fine in other settings. Microwave is about 14 months old
Older microwaves can develop any number of quirks.
Instead I suggest calculate the number of cooking time minutes needed and use that for your potato.
Be sure to fork a few holes into the skin of the potato so it doesn't "blow" and redecorate the inside of your micro.
Jan 02, 2018 | Samsung Microwave Ovens
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
My wife overcooked a potato to a crisp in the microwave. The microwave doesnt work at all anymore. No life. Breaker good. But my smoke alarms do. Any answers
Without the full model number, I can only give a general answer.
I would suspect that the overheating damaged the thermostat / thermal cutout that protects the magnetron. Hopefully it did its job.
This most often occurs when the microwave is left to run unattended, a big no-no as mentioned in the owner's manual.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Oct 01, 2011 | GE JVM1860 Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No power
Hello there:
what you are going to have to do is:
(1) remove the screws in the back that hold on the cover than look under the microwave and see if there is any screws there and remove them also
(2) now remove the cover and look up towards the front right side top area and you should see a fuse remove the fuse and replacce it than plug in the unit and see if it works if so replace the cover and all screws and you are good to go ok?
If none of the above have seemed to help than i would contact a local authorized repair shop and have the unit serviced ok?
i hope that this is very helpfull for you
best regards michael
Sep 10, 2009 | Microwave Ovens
My Frigidaire Microwave caught on fire
The owner's manual warns of the dangers of overcooking potatoes and similar foods and not to ever leave the oven unattended while it's running.
If for some reason you don't have your owner's manual, you can download Frigidaire owner's manuals and installation instructions here.
Are you looking for help to get your microwave working again?
Chances are it's just an opened flame sensor (cavity thermostat / thermal cutout / T.C.O.). Its job is to cut power if there's a fire.
Accessing some components for testing and possible replacement (like the oven cavity thermostat) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Jun 07, 2009 | Frigidaire FMT116E1B Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Overcooked potato overcooked the microwave
The magnetron probably overheated, blowing the thermal cutout / thermal fuse / thermostat mounted on it.
If you or a friend decide to look into it, we have critical safety and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
280 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
