Question about iRiver T10 MP3 Player
Iriver t10 when i put in usb connction it says it says creating db and when i take it out it says file check error and when i try to sync music to it it won't work
  • 2 more comments
  • Endinio Nov 07, 2007
    The same problem. I reformated. But... same old story. What can I do? I cannot acces the player!!
  • nboran Dec 23, 2007
    first when open not open in time . after that file ckeeck error is seen after that Creating DB... is seen
    what can I do
  • Anonymous Feb 20, 2008
    same here ... can't format it.
  • vanscan Jun 01, 2008
    yes I do have the same problem, My Iriver t10 is 2gb appreciate any help to get me going again, thanks
    Scholar:
  • 67 Answers
Try to re-format it. on player go to settings, then advanced then format. select format, say yes and it should reboot. if that doesn't work you need to upgrade the firmware. got to iriveramerica.com, support, ultra portabale support and download firmware updater software. Not a bad idea to upgrade firmware in either case. Your music will be lost when you format but you can simply re-load it from your music manager on your PC.
Posted on Jul 29, 2007
Good
Posted on May 13, 2008
I go to control panel .... format .... set the T10 to Fat32 and hit format.... re-load music... no problem
Posted on Jun 05, 2009
Clicking "Format" does cause a reboot, but after that the original problem is still there. ("File Check Erroe" when powered on without USB. Or "Creating DB" when connected to PC via USB cable, and the PC doesn't see the iRiver.)
Is there any keypress combination that takes it to a more powerful "restore" mode?
Posted on May 23, 2008
Ineed a usb cable for a t10 iriver mp3 player
Computer shops sell USB cables. Take your Iriver player with you to the computer shop because the USB cables come with different size connectors and you need one that fits your player.
Mar 03, 2013 | iRiver Audio Players & Recorders
Problem copying songs to iRiver H320 music player
This sounds like a drive error.
Try right clicking the drive in windows explorer  then properties>tools>error checking>check now and tick both boxes and then start.
Oct 17, 2007 | iRiver H320 MP3 Player
My boyfriend deleated all the music from my iriver mp3 and now i can't get it to change mode. i change the battery i even pug in the usb and it is still say scaning for music
If your computer recognises it, then all you have to do is to sync the music across from your playlist in windows media player. This should unlock it. (Change your boyfriend too :D)
Jan 24, 2010 | iRiver T10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
File check error
i have file check error prloblem plez u can solving this problem
Dec 20, 2008 | iRiver T10 MP3 Player
Irivet T10 "file check error"
i threw mine at a wall but that only made it worse
Jan 13, 2008 | iRiver T10 MP3 Player
IRiverT10 1gb
well i have an iriver t10, but i can't get any music on it...
Sep 12, 2007 | iRiver T10 MP3 Player
IRiver T10 512 MB USB Freeze
May 25, 2007 | iRiver T10 MP3 Player
My iriver T10 is not being detected
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at NOHEMYGIRALDO@SBCGLOBAL.NET
Nov 26, 2006 | iRiver T10 MP3 Player
iRiver T10 MP3 Player Logo
997 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
