Question about Kenmore Washing Machines
Front loader kenmore M# 41744252500 vibrating/shaking like crazy
My washer is front loader until resently it has been vibrating/shaking very vigrously sometimes ihave to stop it just because am afarid that it will blowup or some like that what needs to be done to this issue?
I have a 4 417-43142200 that also made a terrible noise when spinning. I found that the counterweight (a piece of curved concrete) had fallen out past the rear pulley and into the bottom of the washer. When the unit was on spin cycle it would wobble and bash against the counterweight. I bolted the counterweight back in place and it was fine. The engineer who designed this part of the machine was not very thoughtful since there is nothing to hold the counterweight captive. If the bolts had been placed further out then the block would have been captive.
Posted on Mar 06, 2009
  • 112 Answers
The drum mounts to a spindle on the back. On these units, it is common for the tripod mounts for this particular design to crack and break. On almost every call I have had for a terrible vibration on these models, this has been the problem. The remedy is to replace the front and rear tub, as well as the basket. It is also recommended that you replace the drain pump at the same time. Most of this should be covered under at least a parts warranty.
Posted on Oct 28, 2008
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
HE Kenmore washer vibrates quite strongly on high spin, which is the Normal default for the machine. I have had it adjusted for levelling, then had to have a new machine delivered when the vibration...
most of the kenmore front loaders is that way,, if it is on a pedestal or on the second floor it makes them worse,, lg samgung electrolux all shake to a extent but kenmore is the worst
Jan 23, 2011 | Kenmore Washing Machines
I have a front load washing machine and vibrates like crazy. Any suggestions.
make sure its leveled. second floors are bad for them. soft floors are bad. recomended for the garage with a concrete flooring. if it has a pedistal it shakes more
Feb 05, 2010 | Kenmore 24032\24036 Top Load Washer
What does error message F 11 mean? Kenmore front loader elite. Thanks!
This usually points to a wire that has rattled out of its socket on a kenmore washer. with all the vibrations in a washer, cables do shake out of place, you should take the top panel off by unscrewing it and sliding it back so you can get to the front and back wires and check every connection is clean and secure.
should fix your problem and save about $65USD
Jan 02, 2010 | Kenmore Elite HE4 Electric Dryer
Washer vibrates alot
The following link may give you some pointers on what to check on your kenmore Elite to resolve the vibration problem:
This could be a matter of the legs becoming unlevel during the move, a shock absorber becoming damaged, or it could be the new location. These front loaders need a good firm and level foundation. Read through the link provided and let me know if you have any questions. I hope this helps you solve your problem.
Dec 18, 2009 | Kenmore Elite 45986 Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Open Questions:
Washing Machines Logo
483 people viewed this question
Sal De
 Brian Main
Brian Main
