Question about Belkin Computers & Internet
Cannot get into belkin load program to change password and code
    Problem Solver:
  • 15 Answers
If what you are referring to is a Belkin Wireless Router you may need to login from the Internet Explorer browser and type in the IP address of the router. Typical routers are set to 192.168.1.1 but if this does not work for yours you may need to do a few steps to find it...
1. Click on the start button on the desktop and click run...
2. type cmd and press enter
3. type ipconfig and press enter
there will be an entry that shows up that says 'Default Gateway' this will more than likely be the IP address you need to use to get to the login page for your router.
If the problem you are having is not actually getting to the router login but you don't know the password is... then you will have to do a hard reset of the router resetting everything back to the factory settings.
1. there will be a reset button on the back of the router
2. while the router is plugged in and the lights are on use something to push and hold the reset button in.
3. when... A. The lights on the box shut off. B. 5 - 10 seconds has passed...
4. pull out the power cord from the back of the box **WHILE STILL HOLDING THE RESET BUTTON IN**
5. now release the reset button and plug the power back in.
6. allow the router to preform its bootup and then attempt loggin in again.
**after doing the reset it will use the original logins as well for the router, typically...
Username: admin Password: password
Username: Password: admin
there may be other possible logins that it defaults to as well.
Posted on Oct 29, 2008
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
Hello:
The Belkin F5D7231-4 has no password by default. If you changed the password and can't remember it, you can reset the router to default settings by pressing and holding the recessed reset button on the back of the router for at least ten seconds.
Manual: http://cache-www.belkin.com/support/dl/f5d7231-4.pdf
May 02, 2014 | Belkin (F5D7231-4) Wireless Router
I have a Belkin wireless router- I haven't used it in a while- I have a new laptop and it keeps asking for a security code. I've tried all the numbers on the router and even tried with the 00in...
if you had a cd that you installed it should be in the program.
Look for a Belkin program on your computer, the password should be there, you can change it after you've found it.
Sep 23, 2011 | Belkin N150 Enhanced Wireless Router...
How do I find my wep key number
You can find your Belkin WEP key on its bottom or back side, Normally all other routers are coming without password, but belkin asks its physical address has its WEP password,
you can change it's password and SSID by login in through internet explorer, both the username and password of router can find on it's backside, then follow some easy steps to change SSID (wireless name) and wireless password (WEP) min 8 charectors,
please don't try to change your username and password provided by your Network provider if are not a professional, (connection may lost)
Thank you rate if you succeeded
Sep 03, 2011 | Belkin Basic Wireless Router
Can't remember my password
If you have NOT changed the default password, that is:
Manufacturer Model Protocol Username Password BELKIN F5D6130 SNMP (none) MiniAP BELKIN F5D7150 Rev. FB MULTI n/a admin BELKIN F5D8233-4 HTTP (blank) (blank) BELKIN F5D7231 HTTP admin (blank)
If you have changed it, just reset the router and use above passwords.
Aug 02, 2011 | Belkin Basic Wireless Router
Password has been changed
I got this same error on my Belkin N150 router.
I called Belkin Tech Support (877-736-5771) and they had me uninstall the Belkin Setup Program via Add/Remove Programs, and now everything is fine.
I'm not saying this will solve your problem -- you should probably call Belkin Tech Support just to be sure.
Dec 01, 2010 | Belkin (54G F5D7230UK4) Wireless Router
I have a belkin wmp11 but lost the code to put it on a new computer how do i get a code
  1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu, or type 192.168.2.1 into a web browser.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
  4. You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
  5. Click the Wireless > Security link from the page menu on the left-hand side.
  6. On the Wireless > Security page, you can retrieve your password(s) from the fields to the right of the Pre-shared Key (PSK) > entry.
  7. Uncheck the Obscure PSK box to view and retrieve your password(s).
  8. Re-check the Obscure PSK box to obscure your password(s).
Uncheck the obsucre psk
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
Add password to Wireless G
a #, address was provided so you can set up your belkin utility's thru your internet browser( just type the address provided into your browser then it will ask for a security code( by default its blank just hit submit) then you should be able to control your belkin settings. don't forget to apply changes after making a change in the settings.
Oct 01, 2008 | Belkin (F5D7230-4) Router (587009)
Installing wpa security belkin f5d 7230-4 router
youre supposed to type it in when connecting to the wireless. if it wont connect. click the lil star on left on the "view wireless connections" in xp then remove the named router in the list bellow.(it stores old password) and wont connect with old password.
Aug 20, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
