Question about Sanyo AVM-2751S 27" TV
No signal from My Antena
A while ago my a couple stations used to go out for a few seconds and then come back up, I thought it was just signal problem from the stations. But right now none of my stations come up its all static. And my DVD and games dont come on. when I click on auto search it goes through all the stations and says No signal from antena check connection
    Problem Solver:
  • 7 Answers
Sounds like the tuner has went bad, have you tried to hook it up with audio- vidio jacks or through your vcr??
Posted on Apr 16, 2007
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
I cant tune the HDB842 to my TV. its obviously working because the original free to air stations (2,7,9,10) come up a lot clearer when i switch it on but the new channels (HD1, Seven2, ABC2 etc) do not...
Ur tv is not getting a strong enough tv antena signal that,why ur tv is not getting,all the free air DTV broadcasting all the tv stations.Try it with a better antena like a roof antena or a digital antena.After have a better antena install and hook up,rescan all the DTV tv stations again,will appear.
Oct 20, 2010 | Televison & Video
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem...
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Oct 13, 2010 | Polaroid FLM-3201 Television
I connected my 42' to a antena when i serch channel didn't get any signal
Depending where you live, you may not be able to pick up a signal. I just completed an install where the cleint did not subscribe to cable, thus wanting to use an antenna. Just using the antenna did not work. We added a booster and a 20' mast for the antenna and he still only received a few stations. Also if you live further than 50 miles from a tower and have obstructions, you will get little to no signal. Just for assurance, from the tv remote you should have a options in the menu. You should be looking for "connection" with a selection of "cable", or "air". Once you select "air" it should do an auto search for all stations and/or signals. If you simply did a plug and play, it may not work.
Jun 30, 2010 | Protron PLTV-4250 42 in. LCD Television
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
Digital picture freezes for split second every now and again
U have Cable,Satalite,or Teleticom Siginals ur incoming signals 99.999%.Digital antena about 95%.Roof antena about 90%.Indoor Analog antena about 89%.Yes the signals is varies u will have freezes,not ur tv
Oct 15, 2009 | Televison & Video
No radio reception
MIght be an antena problem. Cheapest a quickest way to find out if the problem, your local autoparts store will sell a cheap replacement antena. Pull out stereo use this antena to check if more stations are picked up or use speaker wire about a foot or so in lenght and stick the wire in the antena port of the radio and see if you pick up stations, if so then your antena needs replacing.
May 16, 2009 | Car Audio & Video
XM Radio Reception
Signal on xm is full power (3 bars) stations 1 - 75. All stations 0 to 1 bar above station. Just started happening 2 days ago.
Jun 24, 2007 | XM Radio (XMP6000)
Sanyo AVM-2751S 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
