Question about Dryers
Lint light on and won't start - Siemens ultrasense dryer
I've done everything suggested - cleaned lint filter, vacuumed lint out, unattached from vent. I've already spent hundreds of dollars over the years having service people work on this. Is there any reset button? Is there anything else I can do myself?
  • 489 Answers
SOURCE: front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Posted on Apr 28, 2008
  • 67 Answers
SOURCE: whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Posted on Jul 14, 2008
  • 409 Answers
SOURCE: Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Posted on Sep 25, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
Ultrasense dryer sending lint filter red light, E01 message and it is beeping after starting to dry.
Try unplugging for a _full_ 24 hours. If problem still exists, bad computer board.
(I feel like I should copy this answer to a notepad and paste it every time I see these questions. This is why I avoid computerized appliances like the plague. Owning such appliances is _truly_ worth having extended warranties).
May 18, 2015 | Dryers
Always air filter clean
If the light comes on after it\'s started its cycle, that sounds like your dryer actually has a sensor in it (my dryer just has a fake light to remind you to clean the filter, but there\'s no sensor).
Either there\'s debris accumulated inside that\'s blocked the sensor (it\'s working correctly), or the sensor itself has failed (part repair).
It\'s possible your filter itself isn\'t letting enough air pass through any more. Do a quick test: run the dryer with the filter out and see if the light still comes on.
If the light still comes on, see if you can remove some lint from the dryer. Remove the filter and get a vacuum nozzle in as far as you can to try to suck out any lint that got past the filter.
Also check the exhaust. How recently was your dryer duct cleaned? Could it be clogged? Disconnect the exhaust from the wall and inspect the pipe. If you see a *lot* of lint and dust it should probably be cleaned. It\'s not expensive - call a duct cleaning company and ask them to clean your dryer duct and nothing else. No addons, no extended service plan, nothing - just clean the duct.
By now you\'ve checked the air going in and the air going out. If it still continues this behaviour I would look at the sensor itself. It\'s almost certainly cheaper in the long run to call in a repair person for that.
Mar 03, 2014 | Dryers
Model AE9433 won't heat, says clean lint filter
If every thing is clean you mite need to reset it, unplug it for few minutes.
Dec 16, 2012 | Dryers
Long time to dry clothes, good heat, bad air flow?
He is talking about cleaning out the unit for lint that may block the unit somewhere from drum to where it vents outside---I would have a pro do this---seen ones who for 30 dollars will come and clean and clear it as well--lint can present a fire hazard and there are hundreds of fires reported each year that are caused by this---regular cleaning can prevent that and improve performance and extend the life of the dryer and your home.
Dec 09, 2012 | Dryers
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
My clean filter light won't go off on my frigidaire & my dryer won't turn on
Did you try to remove the back cover after unplugiging your dryer ,to find a lot of lint in the back of the dryer? Some times you may have to clean in this area for fire safety. Maybe this would sold your problem.
Jul 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer won't work! The light works and the lint
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dryers
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
I have a 1992 gmc serria 1500. Some times it does not start. if i wait awhile and go back to it then it will start up right away. when it does not start the power turns on and does not even try to turn...
Assuming you've got a clean and tight connection to the battery, there's a good possibility that the starter is bad. A bad starter will occasionally work when cold but once it heats up, it requires more power to get it to engage. If when it's hot, everything else is working, ie headlights bright, accessories like power windows work, then it would certainly sound like a starter problem. Most with these symptoms end up changing out batteries, alternators, only to find out that a few days later, the problem returns and you've already spent a few hundred dollars. If you like, you can take the truck to 1 of the auto parts chains that offers free electrical diagnostic tests. This would confirm your battery and alternator are fine prior to making any major repairs.
Jul 29, 2011 | 1992 GMC Sierra K1500
Open Questions:
Dryers Logo
431 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
