Question about Dell Axim X30 Pocket PC
I want to connect to my wireless Internet connection
Please halp me connect to my wireless internet using my PDA Model Dell Axim X30
  • 1 more comment
  • 4946 Nov 26, 2008
    My router connection is excellent, my email outgoing and incoming server is defined but the internet connection is not happening.
  • PERK89 Jan 07, 2009
    I was able to connect to my @ home wireless until I had to do a hard reset. I can see my connection and other avaiable connections ,but cannot not connect with thepc pocket.
    FYI I don't think it's my wireless router since I'm able to connect to the internet on the laptops in the home. Please help. Thanks
  • Anonymous Feb 09, 2009
    wireless is not finding my wirless router and i it says i need to configur either to use internet or work click settings
  • 33 Answers
If everything is working as it should. All you have to do is turn onyour Wi-Fi. You will then see a popup asking you if you would like toconnect.
You may need to add a compact flash wireless card:
  • http://wifi.aximsite.com/wifi-faq.html#_51-card
  • http://www.amazon.com/SPECTEC-Wireless-Networking-Connection-Notebooks/dp/B000BD9PBQ
You'll find a comprehensive axim wifi guide here: http://wifi.aximsite.com/
Posted on Oct 28, 2008
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
Internet and Bluetooth Problems
The issue you have is that the Axim does not have any built in connectivity for networking. In order for the Bluetooth to connect you, you would have to first pair the Axim to a Bluetooth enabled phone that can support Internet connections. Bluetooth on its own can't connect to the Internet, it is a protocol to link devices together.
The easier way would be to buy a wireless 802.11 compact flash card that will support PocketPC and then use a wireless access point to connect to the Internet.
May 11, 2009 | Dell Axim X5 PDA Snap-On Thumb Keyboard...
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Connect to the Internet
ok, this is a little technical, dell decided to make a complicated WiFi system for this, but once ou get the hang opf it you will be able to connect in no tim.
1. push the WiFi button located on the lower right side , it kind of is flush with the body
2. wait about 20 seconds, if the WiFi meter in the lower right corner of the screen does not change the you will have to go deeper into the system.
3.hopefuly you have noticed the blue light flashing by now, if it has an erratic flash , it is searching for a signal
4.no wifi yet? ok use the stylus to tap the wifi meter bar on the screen, this will show a menu consisting of a (WiFi radio on/off option, edit profiles option, WLan status option, site survey option, advanced, and versions.
5.tap the WLan staus option, this will bring you to the menu, this menu can also be accessed by going to settings. anyway look at the bars for link quality and strenghth, if they have a little bit of blue or none at allgo to site survey at the bottom of the screen
6.this menu shows al the available wifi networks in your area, ifnone show up, and you know you are near one tap the profiles setting, this will show all the nearby sites you can tap and hold any of these sites and manually connect to the internet that way.
7. I warn you , the dell x30 is a little wonky a great PDA and usually works great for the internet but sometimes it jsut plain refuses to actually connect to a site, even though it has a connection. I haqve found the best way to cure this is to do a soft reset, and reconnect.
If this still doesnt work for you, feel free to repost this question or email me, i might be able to help with some more details
Mar 11, 2009 | Dell Axim X30 Pocket PC
Cant connect to internet using my dell axim x30 helppppppp
http://www.fixya.com/support/t1775615-connect_internet
just answered this for someone else, if you have any other problems get a hold of me on twitter @clarkb16
Feb 23, 2009 | Dell Axim X30 Pocket PC
I can't connect to the internet with my dell axim x30
I have the same problem. I have a router and WLAN in my house. I actually connect to the network, the pocket PC says the strenght of the connection is Excellent, even green connection bars, in the right-bottom corner are visible.. But when I try to ping any other computer connected to the network it says NO RESPONSE, not mentioning being unable to surf the net with browser. However, i recall that if you have some wierd kind of encryption, ie. WEP, or WPA or some other - some devices can have problems connectiong to the router(access point). Please somebody comment on what i've mentioned.
Dec 09, 2007 | Dell Axim X30 Pocket PC
Connecting to Internet with WiFi
to phill -
Axim X3 cannot connect to Wifi, only X3ihas built in wifi
Jun 20, 2007 | Dell Axim X3 Pocket PC
Can Not read SD Card
Have you tried the SD card in a digital camera? also is the card working correctly?
About the internet it will have to be correctly set up which means some fiddling around with the connections settings
Aug 05, 2006 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
628 people viewed this question
Alun Cox
