Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
Occassional starts but shuts down after several seconds. Will not start after that
I plug in the 1750 PSI elec press washer. All systems are go. Usually it does not start. But occassionally it start running and then shuts off after a few seconds. I take the top cover off and it starts but then shuts down also.
What is wrong and what is the fix?
3 Suggested Answers
  • 68 Answers
SOURCE: C/H 1750 Washer will not start with water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Posted on Nov 09, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
Karcher k3.86 on/off switch does not work
If you are certain it is the switch, try looking on Ebay for a replacement switch.
Apr 16, 2014 | Karcher 1750 Psi Elec Pressure Washer
1715 psi
Check the screen at the inlet, where the water hose hooks up. These get clogged often because bugs like to crawl up inside hoses and build nests. If it is not that, then you either have a problem with the valves (popet) or the unloader part of the pump. You will need to look at a parts break-down and access these for disassymbly to determine if they are damaged. Find replacement parts either in your owner's manual or Karcher web site or pressure washer dealer in the yellow pages. Good luck.
Feb 26, 2012 | Karcher 1750 Psi Elec Pressure Washer
The water is pulsing out rather than a steady stream
it sounds like you have a air leak make sure all your fitting are tight if you have a filter make sure the filter isnt clogged if that doesnt fix it it sounds like your pumps ceramics might have been damaged in the pump its self
May 12, 2011 | Karcher 1750 Psi Elec Pressure Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
try running the machine without the hose attached if the machine runs ok then it is probable the there is a blockage in the nozzle if the the machine still cuts out then the pressure switch will probably be stuck or faulty this switch will be inline with the on/off switch and the motor it can be checked using a multi meter after dissconecting the power.
Oct 14, 2007 | Karcher 2500 PSI Pressure Washer
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
354 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
