Question about Coffee Makers & Espresso Machines
How many ounces of coffee grounds for a 1.5 gallon pot?
2 Suggested Answers
  • 35 Answers
SOURCE: How many ounces or cups
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Posted on Oct 13, 2010
How many ounces in 1 gallon of water
In the USA - 128 ounces = 1 gallon
Feb 08, 2015 | Home
How much coffee do you put in for 100 cups? thank you
I can't say how much cups but if you want to make 60 ounce coffee Then you need 3.25 ounce ground Dunkin coffee Let 10 ounce each cup so for 100 cups you need 1000 ounce coffee. For that (3.25*1000)/60. =54 ounce ground Dunkin coffee Thanks Please rate my work I gave you a very good answer
Sep 08, 2011 | West Bend 33600 Coffee Maker
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
Oct 12, 2010 | Bunn Dual SH DBC
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Proper amount of coffee grounds for 36 cups
The nice thing about standards is that there are so many of them!
The West Bend parts page for this model is here, and there's a link to download the manual. You can see what the manufacturer recommends.
I do coffee by weight. The ratio of 10 grams of coffee for 6 ounces of water seems most common if you look at coffee websites. Make a couple of cups worth, try different amounts, and then scale up to a full pot when you find what works best for you.
Hope this helps. Thanks for using Fixya!
Feb 20, 2010 | West Bend (58036) 36-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
349 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
