First of all, as this Notebook is installed with SATA Hard Drive, any retail version of windows XP will not be able to detect the Hard Drive because of which you are getting this kind of errors when trying to install XP.
However, to proceed with installing XP in your Notebook, I recommend you to disable the SATA Native Support option which will be present with Notebooks installed with Intel Processor and not with AMD Processor.
You can disable the SATA Native Support feature from the BIOS by following the instructions below :
Start or restart the notebook and start tapping the F10 key which will take you to the BIOS setup window.
In this, go to the System Configuration tab where you will find the SATA Native Support.
Press Enter to select it when the option is hilighted and set the option to Disabled.
Now, press F10 key to Save the settings and exit the BIOS setup window.
By doing this, the Hard Drive in the Notebook will be detected as IDE Hard Drive and you should be able to install XP without any issues.
Please not down that the SATA Native Support option should be set to Disabled even after installing the Operating System in the Notebook.
However, I need to have the Product Number of the Notebook wich can be found printed on a white sticker pasted at the bottom of the Notebook indicated wit P/N using which I can find the Hadware specifications of the Notebook and provide the appropriate drivers.
After the death of Windows XP, almost all notebook PCs come with Windows Vista pre-installed. But if you like Windows XP more than Windows Vista then a simple Windows XP wouldn't suffice for installing it on your notebook PC. If you BIOS has an option to change your hard disk mode from SATA to IDE then you can just pop in the good old Windows XP CD and get it set up within minutes. But if it doesn't, then you have to do it the other way as mentioned below.
You will just be requiring the Windows XP CD and a few softwares and stuff that I will tell you as we go along. You might ask just why wouldn't a normal XP CD do the task? The answer is pretty simple. The original Windows XP CD does not have SATA drivers so it can't detect your hard drive during the installation process. The solution is simpler. Just slipstream them into the CD! So lets begin.
Step 1 : Download and install nLite
This is an amazing software that lets you tweak and hack your XP CD to the core with an extremely easy to use UI. Download and install the software .
Step 2 : Download SATA drivers
You need to get your hands on the SATA drivers next, that you will need to slipstream into the CD. Although there are different version based on your motherboard that you can search them on Intel website or download the standard ones , which work with most of the motherboards. After downloading extract the driver and remember the location.
Step 3 : Insert XP CD and start nLite
Now that you successfully have the tools and utilities, we can get down with the real stuff. Launch nLite after inserting Windows XP CD into the drive. Choose to make an image of Windows XP in a directory of your choice. Click next and proceed to skip import or load previous settings step by clicking next and proceed to next step.
Step 4 : Add the SATA driver
On the next page, you will find a "Drivers" tab. Click on it and also check the bootable ISO option and then click on next. Click on the button at the bottom to insert the driver. Give the location to the folder where you extracted the SATA driver. You will find a couple of inf files, select any one of them. Now select the all the driver files. That is it, click Next.
Step 5 : Burn the ISO
You will now be asked for confirmation, select yes and let nLite integrate the driver and create a bootable image. Burn it on a CD by just hitting the Burn button at the bottom and you will be ready to install Windows XP on your laptop!
