I can't get window (vista, business addition) to see my lexmark X4550 printer whe I plug it into the USB port. I have the lexmark disc that came with the printer but it won't let me continue the installation procedure after I plug the printer into the computer. An help would be welcomed....I'm stuck!
  • Coss May 11, 2010
    Does the install disk you have state Vista on it? If not, you may have to download the Vista drivers from lexmark.
    Genius:
  • 1,605 Answers
Unloug the printer and turn it off.
install the lexmark printer software first. plug in the printer and turn it on.
Vista should see the printer and continue to install the driver.
Posted on Oct 28, 2008
Lexmark x4550 scan problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/g8G3VP. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 13, 2011 | Lexmark X4550 Multifunction Wireless Color...
Printer Lexmark X1100
Drivers for Lexmark X1100 in vista should be built in, in any case I will try to find a download.
Mar 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
Jan 22, 2010 | Lexmark X4550 InkJet Printer
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Need to install Lexmark X4550 but only have MAC disc am on vista
Are you trying to install the Lexmark X4550 to your Mac computer? What is the exact OS of your Mac (i.e 10.3.x; 10.4.x or 10.5.x)?
You have to make sure that the pinter is compatible with the OS that you have.
I don't have a doubt with the printer since you mentioned that it worked with XP. To install the printer to your Mac, please follow the steps below:
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
If the printer will not work, you may download the driver from the Web and install it. Here, I have provided you the link where you can download the printer driver:
http://www.findmysoft.com/drivers/Lexmark-X4550-1-0-11-1-printer-driver.html
Just click the download button and install it.
Have a great day!
May 13, 2009 | Lexmark X4550 Multifunction Wireless Color...
Printer not connecting
To start do the following:
Unplug printer for ten minutes.
Empty printer cue.
Take out cartridges and put them back.
If that does not work reinstall the printer software form disk provided with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Nov 26, 2008 | Lexmark X4550 InkJet Printer
I have a Lexmark x4550 scanner and printer, I need to reinstall the software after my pc crashed. I cannot find the installation disc. What can I do
After downloading,find the file,double click on the file with the mouse, if you get in troubles ,then follow instructions below to reset and reinstall:
  • Download driver from website and run the file.
Note:some printer does not work on Vista
Oct 09, 2008 | Lexmark Office Equipment & Supplies
Printer not Vista compatable
Uninstall the s\w and and download the s\w from lexmark.com ....
Check if ur vista is 32 bit or 64 bit processor....(Right clikc on coputer ikon on ur desktop....go to properties..there ull find if ur vista is 32 or 64 bit processor)
choose the software accordingly
And also check if ur printer is x6170 or X6150...
NOTE: While installing....Unplug the USB cable...plug it back in whe the software prompts u to
Feb 26, 2008 | Lexmark X6100 Flatbed Scanner
k24674
