Question about Cycling
Can a HUFFY VORMAX 18 speed mountain bike w/ dual ASR suspension be made into a rear hub an eletric bike . I ask this question because sometimes the way the bike back drailleur causes a problem? And i
And if you know any cheap bike that can be converted to a rear hub conversion.
  • 1138 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
  • 1138 Answers
SOURCE: trying to reassemble rear wheel gear assembly for
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Posted on Aug 29, 2009
Testimonial: "Thankyou, both sites were very helpful. Excellent pictures & directions both. Easy to follow. Another helpful site I found was bicycletutor.com. "
  • 484 Answers
SOURCE: i hav a problem with my huffy dual suspension
i am not sure if your problem is with the shifters or the drailleurs, or just the cable tension. Start by shifting the front into the low gear and the rear into the high gear, then release the cables at the derailleur. Pull them both tight and retighten. If this doe snot work, go to parktool.com/repair/ and check out their step-by-step information on bike maintenance by clicking on the part of the bike you are having trouble with.
Hope this helps,
matt
Posted on Sep 23, 2009
ftw1952
  • 10319 Answers
SOURCE: We have an 18" boys huffy bike and the chain keeps...
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
Posted on May 22, 2010
  • 1788 Answers
SOURCE: i don't know how to
all nuts and bolts are metric, so you need metric wrenches.
Posted on Oct 17, 2010
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
Jul 23, 2015 | Huffy Cycling
I have a Mongoose Dual Suspension Mountain Bicycle 26 inch that I purchased approx. 2007 and I need the rear wheel axel and bearing assembly. Where would I be able to purchase these parts?
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
Jul 24, 2011 | Mongoose Domain Dual Suspension Mountain...
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
I have a izip ladies electric bike the back wheel is wobbly though we have adjusted it
Have a look here under Servicing cup and cone hubs:http://sheldonbrown.com/wheels/index.html Hope this helps.
Aug 30, 2009 | Huffy Raven 26-Inch Dual-Suspension...
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Cycling Logo
77 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
