Question about Casio Portable Keyboard Touch Sensitive Keys
Ctk 611 key board keys jam
Sir,
Iam a technician and I have a ctk 611 key board .now a days its keys(first eight keys starting on the second key pad pcb)are not working properly. the complaint is that at first,means when the keyboard is on and if the touch sensor is off, the eight keys will work for a single time and it will be displayed on the lcd.After that these keys displays jammed and will not sound again unless the power is turned off.Kindly give me an adice to repaire this problem.
My findings
(1) if the 39th pin is grounded when the keys looks jammed, it will reopen.
(2) 39th pin voltage is around 5 volts ,when other pin voltages (which are connected to the keypads) are around 2 volts.
  • 21 Answers
SOURCE: Won't work
The problem is with printer. It is either a gear alignment is needed or the printer detector is already defective. There is also a case that an I.C. for the printer on its mainboard is defective. The best solution is to contact your authorized service center on your area.
Posted on May 27, 2008
headman333
  • 82 Answers
SOURCE: piano/keyboard won't work through imac
Try to connect to other input lines. If your computer has an input line except for mic input try to connect to it. Then configure the settings in your computer, go to the CONTROL PANEL on your computer click SOUNDS & AUDIO DEVICES then configure SOUNDS or AUDIO or VOLUME or VOICE. Then look for the device listed in your system that is available and compatible, then select the most appropriate. After that click APPLY then OK. There you go.
If this solution Doesn't work you must buy a sound card and for sure it will work. Having a sound card gives you several input lines and there is a particular input line for musical instrument like a keyboard in a sound card device. Installing a sound card is easy, and i'll show you. First you must insert your sound card device into your motherboard's PCI slot (most of the motherboards have 3 PCI slots) choose one and take note that your PCI sound card plugs in exactly in that slot so its very easy. After inserting your sound card install the driver for your sound card, install is easy just follow instruction. If you have done this, there you go.
Good Luck!
Pls. rate me if this helps.
Posted on Jun 12, 2008
SOURCE: Casio PX700 sensors not working
Hi. I don't have a 700, but on the other privia's I have seen, there is a function key combo to turn on and off the touch response. Go to casio, and download the manual. You hit "fn" and then one of the lower keys. There are 4 levels of sensitivity on my machine. -Don
Posted on Feb 16, 2009
danforddan1
  • 192 Answers
SOURCE: Casio CTK-671 No Sound
Try plugging in a set of head phones , if you get sound that way the input jack may be causeing the prob. try pulling it back an forth a few times, sometimes this will free up the head phone jack. I hope its that simple . May be some one will have another idea Good luck DFD please rate me TK U
Posted on Apr 12, 2009
  • 1138 Answers
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Posted on Apr 23, 2009
Casio ctk 611 keyboard error
Turn off "Casio Chord" &/or autoaccompaniment
Dec 08, 2013 | Casio CTK5000 (61Key Portable Keyboard)
WHEN I PUT SD CARD IN SYNTHESIZER OF CASIO CTK 810 IN SCREEN SHOWS FORMET ERROR HOW TO USE THE CARD THEN
hi iam bying on casio key board modal no;cti 810in how playin tamil song witch no?witch retham?
Feb 03, 2012 | Music
Casio ctk-501 the power input cracked on the curcit board i did a bypass wiring over the crack and it got power works again but only till i start playing a bunch of keys then the sound gets stuck and the...
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Nov 17, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
First 8 keys on my Casio CTk 495 keyboard are malfunctioning when I press the 1st key in Casio Ctk 495 instead in one key will be push in became 2 keys are press instead of 1 key. Its in Normal Mode How...
There ARE a couple of reasons ant "keyboard" could
fail in "OCTETS" (as you stated "eight" keys)...
Generally ...
all DIGITAL communications is done in BINARY...
The most ADVANCED computer in the world can
only count to "ONE"...
Conveniently... BINARY is best represented to the
human (raw) interface in either "OCTAL"
or "HEXIDECIMAL"... (either in "bus" connections
or LOGIC (chip) interfaces to those "BUSSES")...!!
So if you want to start looking for .
your trouble... first try to remember where/when
that drink (cocoa, tea, coffee or ... soda) got poured
on the KEYBOARD...
LOOK there FIRST.
Be SURE TO WEAR an ANTI-STATIC wrist band...
ELSE... You will be creating more trouble a you
(mis-)handle highly sensitive semi-conductors...
Hope this helps
Carnac the Magnificent
Feb 25, 2018 | Computers & Internet
Casio CTK 800 spare key
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD or call casio and explain to them what happened and see if they can help :) Steven.
Apr 14, 2010 | Casio Lighted Keyboard LK90STADMC
My Casio CTK-496 Keyboard has three keys (2nd octave F sharp, G, and G sharp that don't play anymore. How do I fix this?
First make sure a keyboard "split" option is not set.
Probably you are going to have to clean the key contacts. They are likely conductive rubber "pills" that are pressed onto a circuit board that has interleaved fingers. Clean both the black pills and the circuit board using ONLY 99% isoprophyl alcohol and Q-Tips.
Feb 17, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Oct 29, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
7,4,1 keys in keyboard are not working also the DEL key not working
Turn the keyboard off, unplug it, take out the batteries. MAKE SURE YOU DO THIS STEP BEFORE PROCEEDING! Remove the metal plate under the octave you are having trouble with. Get a can of compressed air, and GENTLY use it to blow out the strike pads (the part of the white key that hits the computer board) Reassemble and power it on.
Jan 12, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
I Mate K-Jam
Hi There
it seems your phone is stuck in bootloder mode...try to hard reset your phone...and reinstall OS if required....
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Jan 11, 2008 | i-mate JAM Pocket PC
Casio Portable Keyboard Touch Sensitive Keys Logo
143 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
