Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
Paslode nail gun has no spark...good battery and good green light.
Unit has new fuel,charged battery,solid green when contact depressed but will not fire....
jj505
  • 195 Answers
SOURCE: i have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Posted on Apr 09, 2009
jj505
  • 195 Answers
SOURCE: Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
SOURCE: I have a paslode nail framer 900600. the problem i
It may be as simple as making sure the spark plug lead is in the spark unit all the way.( Black box in the handle). Good Luck!! If you get stuck call Adelaide Nail Gun Repairs. They may be able to help you over the phone.
Posted on Nov 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: were can i buy a instruction manual for a paslode
go to Paslode.com and you can download the manual for free. Let me know if you have any problems
Posted on Dec 11, 2009
  • 128 Answers
SOURCE: Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Posted on Feb 19, 2010
Why won't batteries charge?
Those chargers are designed to turn solid green when the batteries are fully charged. When batteries are less than new and have some time on them they will not charge as much as a new one. It is conceivable that either the battery condition is not the best there is or that perhaps there may be something wrong with the charger.
I suspect it is the new batteries not being so new.
Aug 29, 2015 | Shoprider Sprinter XL4
Bostitch GFN1564K cordless nailer brand new wont fire.
take it back to the supplier for a replacement or warranty fix
however as it is electric there may be a safety switch that you have to engage to make it work as it would go off when ever and spray nails and staples every where.
Jun 27, 2015 | Stanley Bostitch Gfn1564k 15-guage...
Nail gun wont shoot
When you say it turns on - I'm assuming you mean the fan runs when you depress the nose? If the fan does not run - the problem is most likely the head switch which is part of the circuit assy in this tool.http://paslode.com/uploadedFiles/CF325_Parts_Diagram_Schematics.pdf
Part # 22
If the fan runs but it doesn't shoot - first - Check your fuel! I have seen many times where someone forgot to activate the fuel before installing it. On the bottom of each cell is a date code stamp - if it is within date, press the nozzle of the cell against a solid surface (bench etc) and you should get a good burst of fuel - if not replace the fuel.
Lastly, If the tool is clean, the fan runs, and the fuel is good but it still won't fire it is one of 3 things: a bad spark plug / wire (uncommon), a bad trigger switch (which is also part of part #22 circuit assy), or a bad ESU (electronic spark unit).
If the basic things don't solve your problem, I would suggest bringing it to a qualified repair shop to diagnose because the parts are expensive to play duck duck goose with.
Feb 06, 2014 | BreatheAudio Paslode Impulse Cf325...
Where is the spark plug on a Paslode 250ii finish nail gun?
GO TO TOOLS DIRECT.COM THE SPARKPLUG IS # 11 UNDER THE END CAP.BUT MAKE SURE YOUR SAVETY IS OK.THE SPARK UNIT ASSEMBLY IS #20 IN THE HANDLE.
Jan 30, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode impulse framing gun is dead, no green light
are you sure battery was charged ? if so , then battery contacts or circuit board may be broken.. but its probably a spark unit( little black box in handle of tool) that has gone bad. fairly easy to replace , but little expensive (60-80 dollars)
Sep 18, 2012 | RTO PasLode 900420 Impulse Framing Nailer
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
Gun was jamming up so i cleaned it now green light flashes but if i disconect wire put battery in then plug wires back in fan runs then stops and green light flashes again what could it be
the green light flashing means the tool is ready to fire. when the trigger switch is depressed or the safety activated the fan will run for a short time and automatically shut off. if the tool is not firing then it could be a loose connection of the circuit board or the spark unit. Let me know what the exact problem is and I will try and help further. Also check the expiration date on the bottom of the fuel cell.
Apr 16, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode framing nail gun, bought a new battery, charged it (checked the voltage w/meter) put it in the gun and no green light... what do I check??? Bob
I would start with the battery contacts to make sure not corroded or bent, if no light still then you would have to take the handle halves apart and see if you have a loose connection at the curcuit board. Let me know and I will guide you thru how to do this.
Mar 01, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
454 people viewed this question
Top RTO Tools & Hardware - Others Experts
yoopertech
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
