Question about Pool & Spa
Sta rite pump motor C48L2FC4 motor humming and blowing fuse lower water pressure
Humming and blowing fuse - lower water pressure
  • 59 Answers
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
Posted on May 25, 2009
  • 5 Answers
SOURCE: Jacuzzi jet pump doesn't produce much bubbles
A broken jet internal would allow water to run back up the air lines and contaminate the air lines on all jets that are on the same manifold allowing no air to incorperate into the jets stream resulting in low pressure
Posted on Oct 31, 2009
Coastsider
  • 331 Answers
SOURCE: Problem with Sta-Rite 5P2R pump
1 year mfgr warranty and a possible stuck impeller (from debris) or bad motor bearing(s)... You will need to disassemble the pump and inspect the impeller by rotating it and check the motor for a seized bearing and bad shaft seal. Replace both bearings and shaft seal may resolve the issue. If the motor and impeller spin freely, then you might have a bad motor start capacitor. Some motors have a mechanical governor that can get stuck on the high speed switch and the motor will not spin until that is repaired. These type of pumps require some knowledge and skill to overhaul. Seek professional assistance to prevent damage.
Posted on Apr 14, 2010
  • 990 Answers
SOURCE: Pump hums then breaker flips
Something is binding in the pump try the impeller to see if it runs true when you have it apart. It may be cross threaded on the shaft. This is a common problem if you have a air leak in your system.
Posted on Apr 28, 2010
john224
  • 1378 Answers
SOURCE: My sta-rite pump makes a
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 05, 2010
Sta rite pro jet 3/4 hp seems to be frozen..turn on and it hums then quits ..no water pressure
it sounds like you have a bad starting compositor. If your compositor is a black plastic one look next to the spade connectors in the cap and you'll see a little resest hole with a brown stopper in it. If that stopper is black, burnt or leaking oil it is bad. If you have a metal one you can set it on it's base on a flat surface. If it rocks it is bad. If the compositor is good you may have a problem with the windings and either need to replace the motor or have it rebuilt.
http://www.austinpooolspecialist.com/
Jun 25, 2014 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Well pump losing prime
you might have a leak in the foot valve, you can try installing a check valve several inches before the intake to maintain a prime, or check and clean/replace the foot valve.
If the pump ran dry, check the inlet fitting. the pump can get hot and melt pvc piping connected to it, causing air to leak in the inlet side.,
Feb 14, 2014 | PENTAIR WATER Pentair Sta-Rite DynaPro 1HP
Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Apr 17, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Spa Motor Hums
David
May 17, 2009 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is...
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
Apr 23, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
Pool & Spa Logo
580 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
