How to delete music from sylvania smp2200 mp3 player
I plugged the mp3 player into my computer and deleted songs from it, but the songs are still playing on the mp3 player even though see them when I plug it in to the computer.
SOURCE: deleting mucis off of sylvania smp1015 mp3 player
Plug it into a PC and navigate to the mp3 player and delete the song(s) you don't want. For some reason the Sylvania does NOT like certain USB 2.0 ports such as the ones on my VIA-based shuttle, but it works fine with USB 1.1 ports.
Posted on Nov 24, 2007
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: deleting
For Windows XPTM users, you are connecting the device in MTP mode to the computer by default. You will need to set the device to MSC mode, so go to the device menu\Settings\Advanced\Protocol = > Press Play/Pause key to select MSC mode which will appear as such on the screen. Reconnect the device to the computer, and you can now see those files and delete them.
DO NOT forget to set the device back to MTP mode when finished, so go to device menu\Setting\Advanced = > Select MTP mode.
Posted on May 30, 2008
SOURCE: synchronize to continue your music subscription
I ran into the same problem with my Sansa when listening to legally downloaded audio books from the local library. This is what I found:
  • " Are you sure the player is in MTP(plays for sure) mode when you transfer it? You can check by going to settings>usb mode on the player itself. I think it needs to be for you to use library files like that. " (This worked for me)
  • "are you copy and pasting the files? if so you will need to use WMP to sync the files. copy and paste might not be transferring the license." (didn't try this -- didn't need to)
Hope this helps.
Posted on Feb 13, 2009
SOURCE: wanting to delete some music off mp3 player
try to plug in your mp3 to your computer and open the file where all your music is in your mp3 after it is connected. then just simply delete them off the folder and it will be deleted off your mp3. or try selecting a song on your mp3 and go to settings on your mp3 and try to delete it off there. sorry if it doesnt work for you.
Posted on Mar 17, 2009
I bought my kids sylvania smp2200 mp3 players. drug songs over from itunes. only one song will play even though I plug it in to the computer and it shows many songs and will easily play on the computer. ...
Check the format of the songs you moved over from Itunes.
The smp2200 will only work with MP1, MP2, MP3, and WMA formats. You can check this by looking at the files on your computer.
Good luck.
Semper Fi,
Z
Feb 15, 2018 | Sylvania SMP2200 2GB MP3 Player -...
My VL /340 mp3 player wont' let me delete any music from it. How can I delete songs?
to delete song plug it on a computer and delete the song you want to delete. ::)
May 05, 2011 | Visual Land VL-340 MP3 Player
Just got a smp2200 mp3 and can't figure out how to put music on
Hey,
It works just like another drive letter - plug the usb into your computer and then into the mp3 player. If you go into My Computer there will be a new drive letter with Removable Disk - just drag and drop your mp3's or folders into it
Dec 27, 2009 | Sylvania Audio Players & Recorders
I can't delete music or photo files already on my mp3 player, please help me
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Nov 20, 2009 | Sylvania SMPK8858 MP3 Player
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
How do you delete songs/videos off your music
When you've plugged your device into your computer go to MY COMPUTER on your desktop. Click on the GPX device. You can view, play and delete music, picture, and video files from there.
Aug 30, 2009 | GPX ML648B MP3 Player
I uploaded some songs in my coby705 mp3, but when i deleted the songs in my computer howcome it delete also in my mp3 when i uploaded a different songs? how can i save the songs in my mp3 sothat it won't...
Don't have the Mp3 player plugged in while you are deleting them. and if you don't have it plugged in then just make sure you have enough space to keep adding songs.
Jul 28, 2009 | Coby MP-705 Digital Media Player
Sylvania SMPK8854B - Deleting Music?
click the song u want to delete, press the delete button. click confirm
Jul 27, 2009 | Audio Players & Recorders
When playing my mp3 the songs that i have downloaded off my pc from a paid site, across the screen of the sansa says synchronize to continue your music subsription. the songs will not play please help me
Even though you should be able to resynchronize the files through Rhapsody in order to update the licenses on the music files, in my experience with this player, you have to go through a long, painful process:
1) Open Rhapsody
2) Connect your mp3 player to the computer
3) Delete the songs off the player itself using Windows Media Player - but make sure you still have a copy of these songs on your computer
4) Reload the Rhapsody songs
If your subscription to rhapsody expires, you will no longer be able to use the songs unless you buy them from the Rhapsody Mp3 Store.
-Tha Mp3 Doctor
Mar 22, 2009 | Audio Players & Recorders
Song's won't load, even though the files show
Yeah, the songs are in the wrong format for your player.There are some DRM-protected songs that allow you to play the song on your computer, but they won't actually play on an mp3 player even though they appear to transfer. If you download ALL of your songs in mp3 format, you will never have this problem.
-Tha Mp3 Doctor
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
91 people viewed this question
 Grubhead
Grubhead
