Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool accubake, after self clean, doesn't work, replace thermal fuse, not temp doesn't go up, only lowers
This is second time, after self clean, we have had to replace the thermal fuse, Now when we start it, bake comes on at 350, if we want to raise temp, we push up button, but temp lowers, if you push lower temp, it still lowers?
  • hong8 Dec 18, 2008
    I have the same problem. Where is the thermal fuse ?
2 Suggested Answers
SOURCE: E2/F2 Error
The door lock that is normally used in the self cleaning cycle is locked all the time. You can open the door using a paper clip to trip the latch and the oven operates normally. Can I cut the latch off and not affect the cleaning cycle?
Posted on Dec 15, 2008
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool accubake RBS275PDB6 will not heat up to preset temp
I am assuming the lower element is not working well. Go ahead and replace it. But first , go turn your breaker off to the oven and then back on. Often times it can be tripped but not showing due to the other poles not being tripped. The lower element is the cheaper one also.
Feb 24, 2013 | Ovens
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
Whirlpool Accubake RBD306PDB - Fans won't stop + codes F2 E1
yes. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper. good luck.
Jan 21, 2010 | Ovens
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
279 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
