Question about Hotpoint Washing Machines
Hotpoint WMD960 F18 error code - Hotpoint Washing Machines
I had the F18 fault.Nothing much worked except drain pump.
Simple solution for me was:
1)disconnect power 2)take off top of machine(2screws at rear) 3)locate the connector which fits on the rear of the main led display panel.4) Pull it off, squirt switch cleaner and replace with plenty of wiggling! 5) Put it back together and start washing !
Steve Brighton
Posted on May 04, 2013
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
F18 is a drainage fault.
The appliance has a set time to drain if it doesn't drain within that time F18 appears in display
Diver 1
Posted on Feb 08, 2008
  • 6 Answers
SOURCE: Error code f18 WMF940P
hello, this is a communication error between the main brain board of the machine inside at the bottom and the control board where you push the buttons to operate the machine. most likely a broken wire between the 2 need to do an electricl continuity test between these boards on the blue cables that connect them
Posted on Jul 23, 2010
chans007
  • 66 Answers
SOURCE: The only problem is when
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • or
      • The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
Posted on May 17, 2011
  • 6277 Answers
SOURCE: Hotpoint wmd960 not spinning, Error
Indesit (Hotpoint, Ariston) F05 decodes as 'pump block'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 09, 2011
  • 6277 Answers
SOURCE: Hotpoint WMD960 on start says ' no water supply '.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
Thanks and good luck,
John C
Posted on Aug 14, 2011
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
The only problem is when program starts it does not take any water and after few minutes it starts indicate error code F1. Hotpoint Washing Machine 8KG WMD960 Ultima 1600
  • or
May 17, 2011 | Washing Machines
My WMD960 washing machine is coming up with error code FO5
That code indicates a blockage probably in the filter. If the machine is full of water try to drain it first by lowering the outlet hose into a bucket, of course that may not be too successful if the outlet is blocked but in any event you will need to unscrew the filter and clean it out. Be prepared for some water spillage. I would appreciate your vote for me if you think I helped. w
Jan 11, 2011 | Hotpoint Washing Machines
Error code f18 WMF940P Washing machine has an two occasions come up with message F18 but when un-plugged and restarted the machine works, it has done this twice in 3 months and hotpoint tell me that if...
Jul 20, 2010 | Hotpoint Washing Machines
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
Error code f 18 on hotpoint wd640 ? any idea Everything seems to be working except drium isn ot turning, i hace checked the obvious like the belt.
F18 usually indicates a communication error according to Hotpoints error code list, if you have tried everything that you can and it still does not work, then you are going to have to call an engineer.
Dec 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
449 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
