Question about OKI B4600 Printer
What is oki b4600 error code 120 - OKI B4600 Printer
Buschchris1
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
http://my.okidata.com/PP-B4600-Black.nsf?opendatabase
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
SOURCE: How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Posted on Oct 07, 2009
Testimonial: "The one and only answer!!!!"
SOURCE: resetting image drum after replacing for oki b4600
Posted on Oct 30, 2009
  • 97 Answers
SOURCE: oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Posted on Mar 29, 2010
B4600 error code 173
The thermal cut-off is defective on the fuser. The fuser assembly will need to be replaced. If your printer is less than a year old you can get it repaired thru OKI DATA.
Jul 08, 2014 | OKI B4600 Printer
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
What is err 231 on an oki data b4600
Please list the error message exactly as it appears in your window
Write down the message including the error number "nnn,".
Jul 26, 2011 | OKI B4600 Printer
Error 120
This error is a PU Board Fan motor error.
Check if the fan is properly connected, if necessary replace the fan.
Should fix the problem.
Jul 14, 2011 | OKI B4600 Printer
Err 120
Jun 25, 2011 | OKI B4600 Printer
I have an Oki B4600. I recently replaced the drum & toner. The print is very light and part of the page is illegible.No error message is displayed. Please advise
The problem is most likely with your fuser and will need to be replaced. Contact Oki tech support and see if your printer is still under warranty, you will need to give them your printer's model number and serial number. Sometimes the cheapest solution is to replace the printer all together.
May 19, 2011 | OKI Electric Industry B4600 Laser Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Oki b4600 drum reset ?
Jun 19, 2009 | OKI B4600 Printer
OKI B4600 Printer Logo
146 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
