Question about Minolta Di3510f Bizhub Copier
Minolta Bizhub di3510
Why does it tell me to Change PC Drum?
  • Minolta Master
  • 6,161 Answers
Because after so many copies it needs to be replaced along with cleaning blade and the developer.
try web site below as place to start to get them or have a konicaminolta tech come out do it right, such as clear the counters, install the parts, run the required F8.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 19, 2015
4 Suggested Answers
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
xeerie
  • 347 Answers
SOURCE: my bizhub 200 has message
This means that imaging unit of your photocopier machine should be replaced.its life is over now.
Posted on Oct 07, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: On my bizhub 250 copier,
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Jan 20, 2011
I lost cod bizhub di3510 so plz any one help me
what code???? what are you talking about???? make no sense!!!
Sep 02, 2016 | Konica Minolta bizhub Office Equipment &...
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Bizhub 2510earer coad cobao
The FN finisher unit elevator motor malfunction.Remove the finisher unit and work with out.
Jul 22, 2014 | Konica Minolta Clutch for Di3510 3010 2510...
How developer concentration konica minolta 250
Replace developer and drum when the screen displays "PC DRUM REPLACE" upper left of the screen
May 17, 2014 | Minolta Di3510 All-In-One Laser Printer
How to add konica minolta bizhub Di3510 on windows xp
Down load the driver from konicaminolta or use the disk with the copier.
Jan 22, 2014 | Minolta Di3510 All-In-One Laser Printer
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
How to replace staples in Minolta bishub 250?
just pressing down green colour stapler cart & pull out, its easy to remove it for whole set, unless you are changing bullot pin only, its similay to DI3510 & its equivalent.
Feb 14, 2011 | Minolta bizhub 350 Black and White Copier
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
In minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
69 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
