How do i remove beko wm5101w filter cap - Washing Machines
3 Suggested Answers
  • 6277 Answers
SOURCE: hi i have a beko
Although you say you have tried adjusting the feet I would recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 15, 2011
gavi80
I had the same problem with the same machine, Theres 4 bolts you have to take out on the back that have gray rubber round then, there used to transport the machine from new but need taking out to use it or they make it shake, it will stop when you remove them
Posted on Aug 17, 2012
I have a beko 72675 washing machine how do I open the trap/drain at the bottom , also it is not spinning properly
If your product is not supplied with an
emergency drain hose, do the following
as shown in the figure below:
beko-72675-washing-machine-open-trap-lgjqxkkirb13mdsxkdvj5was-2-0.jpg • Place a large container in front of
the filter to receive water flowing
from the filter.
• Loosen pump filter(anticlockwise)
until water starts to flow out of it.
Direct the flowing water into the
container you have placed in front
of the filter.You can use a piece of
cloth to absorb any spilled water.
• Whenthereisnowaterleft,turnthe
pump filter until it is completely loose
and remove it.
• Cleananyresiduesinsidethefilter
as well as fibers, if any, around the
propeller region.
• Ifyourproducthasawaterjet
feature, be sure to fit the filter into
its housing in the pump. Never force
the filter while replacing it into its
housing. Fit the filter fully into its
housing;otherwise,watermayleak
from the filter cap.
4- Close the filter cap of your product by
fitting the tabs on the bottom into their
positions and pushing the upper part of
it.
Dec 23, 2014 | Beko Washing Machines
Instrukcja pralki beko aa class 1000rpm
unplug the machine, find a good sized pan that is very low. get a wet vac ready, then get to the pump filter there should be a drain that you would use before removing the large cap. either use the small drain "less messy but time consuming" or the large one "really quick but water all over"
Aug 15, 2013 | Watches
How to change water filter on beko fridge /freezer
are some instructions for the installment of your
replacement filter for a Beko AP930X refrigerator. These instructions also include the location of the filter:
http://www.freshwatersystems.com/specifications/MTG_Installation-Instructions-7.pdfHere
Jun 08, 2013 | Refrigerators
I need to check the filter on a beko wm6143s. Where is it?
If you cannot remove the filter cap, do not pull or twist with pliers, this will only break it.
Instead, turn of power and water, pull the entire washing machine out and then tip it backwards at approximately 45 degrees or to the point where it is balanced.
Then undo the only visible screw behind the filter cover, slide entire lower cover to the right. this will reveal three screws, undo these and rotate the filter cap and pump body anticlockwise until the lugs line up with the gaps in the front panel. disconnect the wiring plug from the top then lower the pump below the chassis of the machine.
Remove the black hose on the left hand side by gripping the hose clamp with pliers and pushing off. The offending items (two hair grips and a shirt collar bone in my case) will be visible in the body of the pump, fully withdraw the filter cap to check for other debris.
Reassembly is the reverse of disassembly.
Jan 12, 2012 | Beko Washing Machines
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
Beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Mar 31, 2008 | Washing Machines
Beko eco washing machine
Sounds like a pump problem. Could be a broken impeller, or something has got past the filter and has jammed it. Try removing the filter assembly inside, and see if anything is visible in the pump chamber. It may be too late and the pump is broken.
Oct 17, 2007 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
