Question about Acer Aspire T160 (AST160UA3400) PC Desktop
Computer goes on but does not boot
My computer turns on with the fans at maximum speed and stays at max speed
usually they go to normal speed after a few seconds when my computer turns on
the hard drive turns on
but nothing happens
it just sits there running at max speed
nothing appears on the screen except it says "no input signal" but its plugged into the computer, but the monitor i think is not the issue
it just wont start up
thanx
  • alec1234 Oct 28, 2008
    your first solution is not the problem
    and for the second, i can not install anything or do anything with the computer
    nothing happens but fans and hard drive turn on
  • Anonymous Mar 30, 2009
    I have the same problem, I have change motherboard and processor, even put power supply on a working computer and it is working ok. Removed all devices and removed memory no beeps just the fan
    President:
  • 2,712 Answers
When you start up the PC, do you get any kind of beep sound? If not, I would reckon the RAM modules are faulty and would need to be replaced first. That is the usual cause for this kind of issue. Also when replacing the modules, make sure they are the type supported by your motherboard, ie DDR, DDR2, etc. You will have to consult your m/b manual for this..
If the problem is not with the RAM, ie you hear a beep, but nothing else, I would guess that the MBR of your operating system is dysfunctional, which would mean that you would have to reinstall the operating system.
Hope that helps...
Cheers!
ID
Posted on Oct 28, 2008
  • Swilin Sampson
    Swilin Sampson Oct 28, 2008
    Yup, then its most likely the RAM. Have that checked first.
Blower just started staying on - furnace has been turned of for 6 months
This is a diagram of a blower relay and a fan motor, the normally closed fan relay switch goes to the low speed which is the Heat speed, the low speed is controllled by a temperature delay depicted in the low speed circuit.
The normally open fan relay switch goes to the high speed, which is the AC modes speed , also if you run the fan continuously via the fan switch on the thermostat this is also to high speed.
I suspect the temperature delay's on setting is being reached thus cycling the low speed of the fan.
Nov 08, 2015 | Heating & Cooling
Mitsubishi Lancer 2006 cooling / rough idle issue
Sensors do not always throw codes if they are close to normal parameters, needs to be checked with a scan tool and thermometer.
There is usually a high and a low speed fan relay, as well as a separate A/C fan relay (also high) Your High speed fan relay could be bad, or the fuse for it.
Engine idle surging usually means the coolant is boiling and there is no longer liquid in the throttlebody causing it to go to a high idle because it thinks the engine is cold. Warm coolant closes a valve lowering the idle on most Japanese makes of that year.
Also, sometimes Thermostats stick half open and do not allow enough flow. AND sometimes in neglected cooling systems Water pump Vains are eroded by electralosis causing low coolant flow as well. And a Clogged radiator can also cause this, as by the time the fans run on high it's to late.
May 22, 2014 | 2006 Mitsubishi Lancer
Need the location of the fan resistor,
More likely it's your fan speed switch. If the resistor pack goes bad, usually fan only works on high speed, but is still turned on and off by the fan switch. If yours stays on all time with key on, and won't turn off by the fan switch, probably a bad fan switch.
The resistor will be on the heater case, mounted with two small screws, a small rectangle with a wire connector with 4 or 5 wires to it, and not far from the blower motor.
Dec 20, 2013 | 1997 Chrysler LHS
My daugher has a 2008 prius, had a flat tire and now has the spare tire on. What is the maximum distance and speed she should drive
I do not know the maximum distance, but there should be a wear indicator on the tire. Usually the max speed on doughnut tires is around 50 mph but the owners manual will clarify. Usually the spare will have a max speed posted on it somewhere with a sticker.
Please let me know if I can further assist you.
Mar 28, 2011 | 2008 Toyota Prius
My IBM screen goes dark after being on for several hours. It will return to normal, and then go dark again. Could this be the HDD is getting too hot? Is there a way to increase the fan speed?
Check the energy save settings and see if the monitor is set to shut off after a certain amount of time. Also if the laptop battery gets low it may start to turn off the monitor to save energy. Are you using the computer on a/c power or battery power when this happens? As far as fan controls the settings are usually in the bios but you can sometimes install software that will control the system fan. The BIOS system menu is usually available by pressing delete when the computer boots up(some computers are different button).
Sep 08, 2009 | IBM ThinkPad 570E Notebook
Download issue n inter net issue
try reinstalling your windows your OS might be corrupted from a Virus infection. viruses or worms usually hog your Internet , that might result to a slow internet connection..
Also if you have a 256kbps connection, your download speed of 25KBper sec is normal
because 256,000 kbps / 8bits = 32 KB/s (thats your maximum dl speed)
but assuming there is a loss in transmission about 15- 20% lost your max dl speed is only 25.6 KB/s thats why your connection is normal.
Jan 11, 2009 | Intel Pentium III , 900 MHz Processor
Turns on but no boot
I had this happen sometimes after a windows update/reboot.
If the computer is on, hold down the power button until it cuts off.
Unplug the power cord. Wait for a couple of minutes.
Plug the cord back in, and turn on system.
Oct 27, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
Tower computer
that could only be your cooling fan. initial speed at maximum then turns to lower speeds when system has done POST.
Apr 11, 2008 | Computers & Internet
Acer Aspire T160 (AST160UA3400) PC Desktop Logo
176 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
