Canon iR2525 Jamming at Inner finisher
I have a Canon iR2525 and have just installed a 2-way unit and inner finisher, for some reason the photocopier will always jam after it has exited the 2-way unit and has started to go into the finisher, this only happens when printing in A4 and not A4R - I think that something is inside the finisher towards the back of it which is stopping and jamming the paper. I can do as many copies as i want on A4R - Just not on A4! I have taken the finisher out a few times, i cannot see anything wrong with it, and i have also done the same with the 2-way unit. All connections have been double checked too!
  • 9 Answers
SOURCE: Paper jam / Dell 1710n
Do this You want to check the paperpath so first run a test page you will hear the paper pickup if you stick your ear to the paper tray it should pickup paper within 2 clicks any more than that that means you would need to change the bottom roller and the pad on the tray to be safe, to print a job the printer is timed to do this so if your paper is not picking up in time it will jam (also your fuser the part that heats up the toner on the paper it has a time limit to heat up if it's slow or don't heat up at all you will get a paper jam plus if that happens take your finger and run it across the paper if toner on your finger it's you fuser
Posted on Sep 13, 2007
XboxModifier
  • 123 Answers
SOURCE: printer keeps jamming
can you check to see if there is any paper piece's that might have ripped off a previous print stuck on the carrage bar, open the front flap and try to do a paper feed using the printer function buttions, thus elimiating windows printing... let on ;-)
Posted on Feb 19, 2008
SOURCE: When attempting to print, I
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: printer grabbing the paper very rough, jamming inside
CHANGE YOUR PRINTER DEFAULT
Posted on Mar 01, 2009
MIlfordPrint
  • 90 Answers
SOURCE: inner cover is open
Hi there.
There have been hundreds of complaints about this problem. You can download a driver AND a user manual from the first link listed below. The second link will take you to a really great site for your printer.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11995#DownloadDetailAct
http://damnprinter.com/96/tray-guide.html
Posted on Aug 03, 2009
Documents are print with black spots
more or less remove cartages and clean with alcohol INNER AND OUTER COMPARTMENT
Nov 02, 2015 | Canon Pixma MX420 All-In-One Printer
Problem with my Canon Pixma MP500
Try a hard reset first: Unplug the printer from power source and PC, wait about 5 minutes and replug. Should the issue recur, then the cover sensor is probably faulty. That is the reason you are getting this error repeatedly. The only solution is to send the printer in for servicing and get the sensor repaired/replaced.
In any case, here are the steps to close the inner cover:
1. Press the Open Button (1) to open the Paper Output Tray (2).
2. Raise the Scanning Unit until it stops.
3. Close the Inner Cover
4. Now close the Scanning Unit.
You can also try reinstalling the printer software along with any patches, updates, etc from the Canon website. Make sure you uninstall the existing software first though..
If neither works, then its time to take the printer in for servicing. You could try to contact them by phone first:
  • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
Hope that helps!
Jul 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
What's E00025-2c0
Error in Cover Sensor (PS14) in M Toner Container
Description Unable to detect opening of the Toner Container Inner
Cover when removing the Toner Container.
Remedy Identify the cause of the error whether it is due to link
mechanism to open the Toner Container Inner Cover or
problem at the Toner Container Inner Cover Sensor side. ?
1. Perform the user mode (Adjustment/Maintenance>
Replace Specified Toner) to check if the Toner Container
Inner Cover opens normally (damage, slide of shaft area,
etc.). ?
2. Check if the Toner Container Inner Cover Sensor is
soiled and the installation of the sensor. ?
3. Check the service mode (COPIER> I/O> DCON> P024
bit9) to see that the output value of the Toner Container
Inner Cover Sensor is changed normally when opening/
closing the Toner Container Inner Cover. ?
If it is normal, the value becomes 0 by rotating the Set-on
Drive Shaft with the attached tool and opening the Toner
Container Inner Cover. When closing the Toner Container
Inner Cover by hand, it becomes 1. ?
3-1. When the Toner Container Inner Cover is not opened
although the Set-on Drive Shaft rotates, check the drive
system from upstream (Set-on Drive Unit -> Hopper Unit
-> Bottle Base Unit -> Toner Container Inner Cover Unit). ?
If it is damaged, replace the damaged part and then
perform step 5 and later steps. ?
3-2. When the output value is not changed normally
although the Toner Container Inner Cover can be opened/
closed, check the Sensor Harness (to see if the harness
is caught, disconnected or physically removed, *including
the Relay Connector). ?
If there is no problem, replace the sensor. After checking
the output value in step 3, perform step 5 and later steps. ?
4. If the problem is not solved by replacing the foregoing
parts, replace the Drum Driver PCB (UN4) and then
5. Clear the error in service mode (COPIER>
FUNCTION> CLEAR> ERR), and then turn OFF and then
ON the main power. ?
6. Replace the toner (reinstall the removed Toner
Container) at least once in user mode (Adjustment/
Maintenance> Replace Specified Toner), and check that
toner replacement can be performed normally.
Sep 24, 2014 | Canon imageRUNNER ADVANCE C5051
Pixma 4250 printer 6 yellow flashes
Hey Gary.
The error code is for the inner cover that needs to be close.
1841 *2/1846 *2 Orange light blinking 6 times Description:
The inner cover is open.
Resolution:
  1. Close the inner cover.
    innercover_tcm13-1070771.jpgThe above picture shows the inner cover.
  2. Press the [Resume/Cancel] button on the device to continue printing.
Nov 10, 2013 | Canon PIXMA MX320 Color USB InkJet Printer
How do I clear error E100 on my Canon GP215 photocopier? The paper keeps on jamming continuously.
Odds are you will need to replace the fixing unit. The error code deal with the fixing unit not heating up to the correct temp.
May 22, 2012 | Canon Office Equipment & Supplies
How do i replace a 2006 A6 rear light. I crashed into a wall in the ice and it broke the plastic. I have a full replacement unit.
Rear iignts in rear na, removing and instaiiing
Fig. 325: Rear Lights In Rear Lid, Removing And Installing
Courtesy of VOLKSWAGEN UNITED STATES, INC.
Removing
CAUTiON: • Switch off all electrical components.
. . Switch ignition off and remove ignition key.
o Turn light switch into "0" position.
o Open cap - 1 - for warning triangle.
o Rotate quick-release screw - 2 - counter-clockwise 90 C and remove cover - 3 - from luggage compartment lining - direction of arrow -
Fig. 326: Removing Bulb Socket From Housing, Pressing Catch Bracket Downward
o Disconnect electrical harness connector
o Remove bulb socket - 1 - from housing, press catch bracket - 2 - downward - arrow - to do so
Fig. 327: Identifying Nuts, Clamping Bracket, Inner Tail Lamp, And Clamp Mounting
o Unscrew nut - 2 - and remove clamping bracket - 1 -
o Remove nut - 4 - and remove inner tail lamp - 3 - toward outside
o Remove clamp mounting - 5 - from body cut-out
Fig. 328: Identifying Clamp Mounting, Nuts, Inner Tail Lamp, And Tabs
Installing
Installation is the reverse of removal, noting the following:
NOTE: • Make sure seal between body and tail lamp housing seals properly.
. Attach clamp mounting -2 - at inner tail lamp and screw on nut -3 - loosely.
. Attach inner tail lamp -4 - at body cut-out and make sure grip tabs - arrows - of clamp mounting rest against body cut-out
. Slide clamp mounting - 1 - onto threaded pin of inner tail lamp and tighten nuts - 3 - and -5 -.
Jan 19, 2011 | 2006 Audi A6
What does it mean when the alarm window says "inner cover is open"?
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
Nov 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
292 people viewed this question
jasbo
jasbo
