Question about InFocus LP 600 Multimedia Projector
Infocus lp600 not working
Used projector one problem, however left unit plugged up but had shut down. next day came in and powered up projector. start to power up and then after about 4 or 5 sec simply shut down. power light still on but would not power up.
  • 1,447 Answers
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Posted on Oct 30, 2008
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Sep 13, 2010 | IBM Office Equipment & Supplies
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
May 11, 2010 | InFocus LP 600 Multimedia Projector
Lp600 won't strike
If you replace the lamp but do not reset the lamp hours then the projector will not ignite the lamp to stop it blowing up the lamp and causing further problems. You can reset the hours without the image, on the x2 version you turned on for 1 minute then held down the volume up and down buttons for 10 seconds but all versions vary. The infocus website can usually tell you how though you may have to look for it a bit. Failing that try a firmware update available from the infocus website that should erase its brain so you can start again, hopefully you have kept the original leads it was shipped with to do this otherwise it will cost you another £20
Feb 11, 2010 | Office Equipment & Supplies
Intermittent Power up / dn
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
Oct 04, 2008 | InFocus LP 600 Multimedia Projector
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Feb 27, 2008 | InFocus LP 600 Multimedia Projector
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Aug 14, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
249 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
