Question about Whirlpool Washing Machines
Water doesn't stop filling
Water will not stop filling
  • 1,543 Answers
If you turn power off to machine (or unplug) and washer continues to fill, you need to replace the water inlet valve. (the part the hoses connect to) If cutting power stops the water fill, you have a problem with the water level switch or the tubing leading to it.
Posted on Oct 28, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
Washer doesn't stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Kenmore Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Water keeps running, toilet not shutting off totally, tank will fill then we have to pull up float and hold it a while to stop water, doesn't overflow, just keeps running, doesn't shut off...
Hi snowjobs847...
Try resetting your float level to a lower water level in the tank, the extra pressure put on the seal may make it reseal.
If the above did not work:
You need to replace your "ballcock"...the ballcock (inlet valve) is non-repairable, has to be replaced with a new one if you cannot get it to stop leaking.
Please take time to rate me
Sep 04, 2011 | Home
My maytag home top loading washing machine over fills with water, ie. the switch to stop filling and start washing doesn't go off. I can drain it by setting it to spin.
top loading machines comes with a pressire switch to determine the water level.IT will fill with water till the switch is triggered to stop filling and continue with the next task of washing. there would be a rubber hose connected from the wash bucket to the pressure switch. Check for broken,leaking,bitten by rats hose or probably the switch it self is faulty, which is rather rare.
Aug 24, 2011 | Washing Machines
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Feb 02, 2011 | Keurig B70 Coffee Maker
Nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
291 people viewed this question
Dan Webster
Dan Webster
Sal De
