Question about Vacuums
Scunci turbovac how do i remove and empty the canister?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: need owner manual for Scunci
Hi citykitttyka...
I could not find a user manual, but I found a webpage explaining how to use your Scunci...
Please take time to rate me
http://www.ehow.com/how_5601648_use-scunci-steam-cleaner.html
Posted on Aug 17, 2011
Testimonial: "I appreciate the time an effort you took to assist in finding an answer for me. I was unable to find a user's manual or much of any useful info regarding the Scunci canister wet/dry vacuum cleaner model #52033. Thank you, I really appreciate it. The solution you found was for a steam cleaner. I actually own one, it will be valuable to me when I need it. Thank you."
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Need owner manual for Scunci 52033 canister wet/dry vac
Hi citykitttyka...
Aug 17, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
We have a scunci recharge cordless wet-dry vac model # 52033. The battery does not charge. What can we do to fix this?
if the charger is working, and the battery does not hold a charge for very long, you will need a replacement battery. this is the most likely problem. if the battery does not charge at all it may well be the charger and you will need to replace that. hope this helps
Jun 08, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
Scunci cordless wet dry vac wont hold charge
battery pack has developed memory and needs to be replaced
Sep 19, 2009 | Scunci 52033 Canister Wet/Dry Vacuum
The unit won't charge after plugging in to outlet.
Its the battery cell, its dead and unable to hold a charge. you will need to purchase another cell.
Feb 16, 2009 | Scunci 52033 Canister Wet/Dry Vacuum
Scunci steamer will not heat up
Take the bottom off (Just break it after you get the two normal screws out), find the white wire from the element, bridge the offending fuse located under the special insulation, with a piece of wire, if you cant replace it, re assemble, and steam away. If the lack of that fuse worries you, don't do this, just pitch it.
Jan 13, 2009 | Scunci 52000 Handheld Steam Vacuum
My scunci steam cleaner has a white build up and is clogged. How can i clean it?
I had not used my scunci for a few months and now it is completely clogged. I tried vinegar over night and removed a lot of sediment, but it is still not working. My last shot was going to be to use lime-away. Any suggestions. All parts look in mint condition, but it just doesn't work.
Sep 28, 2008 | Scunci 52067 Handheld Steam Vacuum
SCUNCI RECHARGEABLE CORDLESS SWEEPER
I bought the rechargable sweeper and it was missing a part. The 800# (866-917-6600) is defunct and Conair, who bought Scunci out, said the sweeper division had been out of business for a while now...guess we're all stuck!
May 02, 2008 | Scunci 52004 Bagless Canister Vacuum
Vacuums Logo
83 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
