Question about Sharp XL-MP60 Shelf System
Sharp 5 disc cd player
For some reason everytime i turn on my cd player, it stays on for 5 seconds and shuts off, and in the display window it says "protect"... why? and how can i get rid of that so that my cd player will actually STAY on...
Email i got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Posted on Nov 02, 2008
Why does radio keeps turning itself off after 15 min.?
Half a dozen reasons... If it's exactly 15 min maybe a timer is set? If it's only when it's played loudly or when a bass part is played it could be the wires touching each other.
Jun 07, 2014 | Sharp Cd-dh950 Cd-dh950p 5-disc Compact...
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
CD PLayer no longer recognising CD RW discs
Try cleaning the discs with straight swipes, with a dry cloth, like your shirt, starting from the center and swiping outward.
Mar 01, 2009 | Sharp CD-XP5500 CD Shelf System
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
Cdr s1000 help
Hi Rick
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
regards
Graeme
Apr 06, 2008 | Yamaha CDR-S1000 CD Player
Sharp XL-MP60 Shelf System Logo
554 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
