Question about Vizio L32 32 in. LCD HDTV
My vizio tv starts scrolling through the inputs for no reason and wont stop
The only way it will stop is by shutting it off for about 15 minutes and turning it back on, this works for about a half hour then it starts all over again.
  • dbassett1965
    dbassett1965 Feb 25, 2012
    I do not think it has to do with the remote, I pulled the batteries and it still does it. everything appears to be set for the use of a remote so not sure what else to do. Thank you for your input though
  • Vizio Master
  • 1,198 Answers
Hi
There are a number of things that can be checked.
Check the remote control sensor on the product and try again
Check if there is any obstacle between the product and the remote control
Check if the batteries are still working and are installed properly+to+ and-to-
Check if the appropriate input mode such as tv and vcr is set for using the remote control.
good luck
Kolbrun
Posted on Feb 25, 2012
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Tip
Vizio TV Input Menu Scrolling
Read the recommendation about holding the Input button of the side of the Vizio TV to 'reset' the Input option. The scrolling was driving me a bit nuts so I tried it and "IT WORK GREAT". Certainly beats having to replace the circuit board recommended in other suggestions submitted.. Thank you for you helpful advise.
on May 31, 2015 | Vizio VA Televison & Video
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
My 32 inch Vizio HDTV keeps shutting itself off. I turn it on, the Vizio label comes on, and it immediately shuts down. My son was playing with the remote before this started, and the screen said input...
Reset the TV to its factory settings. For more details, refer its user manual. Unplug the TV from AC mains socket, and replug it after some time, say after 2 minutes or so.
May 11, 2012 | Televison & Video
My input source screen keeps popping up and scrolling through the options - once I select source (example TV) the TV will come on then the input source comes back on and keeps scrolling on its own
My new 4K Vizio 60" M60-C3 started scrolling through input channels on it's own and after a minute would stop and "land" on an input, then I would have to change it to the correct one. Then the volume started "racing" to 100 making it impossible to watch. Vizio repairman came and replaced a small board about 1.5 in. x 5 in. and it is back working again. It fell within the 1 year warranty, so no charge, and he suggested I go back to Wal-Mart where I bought it and spend $59 on the extended warranty. I am certainly going to try and do that.
Feb 11, 2011 | Insignia IS-LCDTV32 32 in. Television
Tv continues to shut off
It sounds like you may have bad connections on the circuits board, more likely in the power supply module or parts that fail when it get warm/hot.
Part: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VW26L+
VIZIO does not really make the TV, they are made by other companies in China per VIZIO requirement and made by the lowest bidders.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Vizio VW26L 26 in. LCD TV
Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
TV will not get off the RGB Screen
I just talked to a tech and fixed mine. unplug tv and hold power button for 1 minute. this drains the compasitors, sometimes they get over charged. if that doesn't work. with tv off hold down input button until tv turns on . it should work. here is tech support # 714-668-0588
Aug 27, 2009 | Vizio VX42L 42 in. LCD TV
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Apr 03, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
129 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
