Question about JVC Kd-r210 Car CD/ MP3 Player
My Jvc radio won't pick up am stations anymore, the FM Stations work fine.
SparkGap
  • 363 Answers
SOURCE: cannot tune to local stations
- The 0.2MHz odd steps are standard for US radios. Try resetting the radio (recessed button under the front panel) If this a US radio then this may not help. If you have lost the manual then go here:- http://books.jvcservice.com/booklist.asp?Model=KD-G400 Come back and say if this helped or not, I could dig a bit deeper.. -
Posted on Oct 04, 2007
freetek
  • 5568 Answers
SOURCE: jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Posted on Aug 25, 2008
memturbo
  • 226 Answers
SOURCE: My JVC car radio/CD player only allows me to scan for stations
the manual can be found here
Posted on Mar 27, 2009
  • 43 Answers
SOURCE: I cant get my raido to save my time or my radio
make sure that you have wired it to the manufacturers spesification, ie, that you have one wire, ususlly the yellow , going to a permanent, not switched power sourse
Posted on Oct 24, 2009
  • 6 Answers
SOURCE: I cant lock t the stations in my JVC KD-R206
Hi, read instructions online for other JVC models as they have the same silly auto tuning function. Page 8 on this link. http://www.jvc.co.nz/assets/pdf-manual/KD-R406.pdf
Posted on Feb 27, 2010
2014grand caravan fm stations all static
Most likely the antenna lead has come unhooked from the back of the radio. AM stations will pick up with the internal working of the radio, but FM stations have to have a working antenna to work. Also make the antenna is tight to the vehicle .
Nov 09, 2017 | Dodge Grand Caravan Cars & Trucks
How do I fix the factory radio-antenna situation where I have no AM radio, when FM works fine?
If you pick up FM. It isn't the antenna. It's an internal radio problem.
Aug 11, 2015 | Cars & Trucks
2012 HARLEY LIMITED ,RADIO WONT PICK UP FM STATIONS,WHAT DO I DO TO FIX?
Too many questions to ask here.
Contact Iron Cross Audio.
We'll see if we can help
Sep 02, 2014 | Harley Davidson 426290 AM/FM Radio
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
97 mitsubishi bad radio reception
It sounds like you are just in a weak reception area. If you feel this is not the case first try replacing the entire antenna assembly, it would be the primary cause of this type of problem.
Jun 22, 2012 | 1997 Mitsubishi Mirage
My concert radio wont pick up AM stations
your probably in a bad place and you wont pick up a signal like if your out of cell phone range, except your probably out of radio range for am stations.
Jun 05, 2012 | 2000 Audi A4
The AM side of the radio receives a few local stations...the FM side works fine...are there two separate antenna...thanks
The antenna for your am receiver is located inside the radio itself and is only a couple of inches in length and about 3/8 of an inch in diameter.
May 08, 2010 | 2000 Buick Park Avenue
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
JVC Kd-r210 Car CD/ MP3 Player Logo
345 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
