Question about Toshiba 43A10 43" Rear Projection Television
No pictuure i have a toshiba 43a10. the power comes on and i can here a relay click, but i have absolutely no picture. hooked vcr up to it and still nothing- no sound either. i have checked a few fuses on one of the boards_ how many fuses does this model have ?
Hello, unfortunately I do not have a solution to this problem, but rather i have the identical problem@ I was wondering whether anyone has found a solution to this? Any ideas? thanks in advance for any help.
Posted on Dec 18, 2006
Hooking VCR to DISH Network Reciever Box
In order to diagnose the problem I need your help.
Have you hooked the dish receiver directly into a tv or another device and had it working?
Have you tried a different cable at all?
Have you tried pressing the ant. button on the remote or tv/vcr button?
Please update me with as much info as possible and I will figure out where the problem is coming from. thanks
May 04, 2008 | Toshiba W627 VCR
No picture
you can't fix this yourself unless you arnt affraid to open it up and do a little bit of soldering
the best thing to do is to find someone locally that will fix it for you
usually somepeople that work at home are cheaper than the proper repair companies
Sep 21, 2009 | Toshiba 43A10 43" Rear Projection...
Have a model 43A10 toshiba tv, has a purple color at very bottom of screen about inch tall. When i go into the menu, looks like writing is not lined up on the lower options of the menu. and partly up...
you either have a color purity problem or a convergence problem. purity can be effected by electro magnets in power supplys of audio amps and subwoofers too close to the tv
Convergence is the ability of the red green blue to drop on top of each other. can usally be adjusted via remote control. Please claify and repost.
Apr 03, 2009 | Toshiba 43A10 43" Rear Projection...
43A10 43in
Yes, the screen can be replaced. The screen is comprised of 3 screens. The Fresnal Screen (inner screen), Lenticular Screen (middle screen), and the Protective Screen (outer screen). Please see below for links to these items.
Need all 3 to complete screen assembly.The only screen that is still available is the innermost screen, which is probably not the 1 you need. You will only be able to find the middle (lenticular) and outer (protective) screens from a distributor that has them in stock as no one will be able to order them from the manufacturer.
  1. Fresnal Screen
  2. Lenticular Screen (no longer available)
  3. Protective Screen (no longer available)
Apr 02, 2008 | Toshiba 43A10 43" Rear Projection...
TV Picture
try unpluging the power and pluging it back in.
Dec 11, 2007 | Toshiba 43A10 43" Rear Projection...
No sound or picture
Your tv is going into protection mode, it has detected a short in one of tv's circuits. thus, not allowing your tv come on. Can give you more detail if you want to repair it yourself, or call a factory authorized repair shop to assist you.
Sep 04, 2006 | Toshiba 43A10 43" Rear Projection...
Screen comming away form housing
I need a picture as I dont understand how the screen can come loose?
Aug 13, 2006 | Toshiba 43A10 43" Rear Projection...
Toshiba 43a10
This problem could be the vertical circuit falure, the sweep circuit falure or the video circuit has a fault. Depending on the age of the set will determine on how much you would spend to have this set repaired. Call out an authorized Toshiba servicer, as they would be able to give you a better estimate as they already or should already have the service manual and parts. Good Luck
Aug 07, 2006 | Toshiba 43A10 43" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
