Question about Kyocera KM-1510 Copier
Drum on model 1510 Kyocera copier
How does one remove the drum of copier Kyocera 1510 in order to place it? Please respond to:
Sam@EstersonTherapy.com
Thanks!
  • estersonpt Oct 30, 2008
    That is for changing the TONER. I am asking about the photo DRUM.
  • 25 Answers
1-6-4 Image formation section
(1) Detaching and refitting the image formation unit
Follow the procedure below to replace or check the image formation unit.
Prucedure
1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit.
2. Remove the waste toner tank and toner container.
3. Remove the two screws holding the waste toner tank cover and then the cover.
4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation
unit.
Developing retainer
Image formation unit
Connector
Posted on Nov 04, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kyocera Master
  • 1,362 Answers
Not familiar w/ that model but I beleive it's the same as a xerox
open the side door open the front and you will see a green lever, move iand pull out the black toner unit slide the other in and lock the lever
Posted on Oct 30, 2008
How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Dec 30, 2013 | Office Equipment & Supplies
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
Kyocera 1810 A400 error. What is wrong and how do I fix it?
This error refers to a bad laser unit. The laser is what "etches" your image onto the drum as it transfers to the paper.
This is the cheapest replacement unit I have found for you.
Here
Aug 23, 2011 | Kyocera KM-1510 Copier
Dear sir my km copier have problem with the image.one side of the image is lighter than other side .i change therum cleaning blade but no result
The cleaning blade just keeps the drum clean. Is the copier on a level surface ? The toner can slide to one side if not. The machine also has a charge wire in the drum unit that needs to be cleaned. To clean it there should be a blue handle that you will pull toward you and then push back into place. Try that and good luck.
Jan 29, 2011 | Kyocera KM-1510 Copier
Kyocera KM-1510 when i turn it on the code C-620 appears and will not function,how can i fix it?
Hello sir; You need to do a reset procedure;
press these keys in order and keep hold them down, "stop/reset" "start" "left copy density", press "stop/reset"key again, then enter U163 press "start" twice to clear.
Sep 17, 2009 | Kyocera KM-1510 Copier
Kyocera KM-1510 error c610
Broken fixing heater wire
Jul 10, 2009 | Kyocera KM-1510 Copier
Maintenance display
Hello sir; You have to change drum & developer then go to simulation U109,110,111 & U130 after that you have go to simulation U250,251 & U345 then it will clear your display.
Apr 20, 2009 | Kyocera KM-1510 Copier
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
Dark line across copies
1-remove drum and turn upside down, is there a black ring on the shiny cylinder, yes, replace
2-remove drum and clean inside of machine look for strip of light, clean for toner
3-if cpying from an automatic feeder, and it does it from there ONLY then lift ADF and clean the small strip of glass.
Sep 14, 2008 | Kyocera KM-1510 Copier
Kyocera KM-1510 Copier Logo
132 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
