Question about Hotpoint Microwave Ovens
How do i remove the vent cover on my hotpoint microwave model rvm1435wk01
5 Suggested Answers
  • 43 Answers
SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Posted on Feb 01, 2008
EwingElect
  • 276 Answers
SOURCE: What is the cardboard cover inside my microwave for?
It may not be cardboard - it may be a material called mica which is located over where the magnetron is located in the unit. This is a protective cover and if it is what I think it is, do not remove under any circumstances, otherwise you may render the microwave unsafe to use.
Posted on Mar 31, 2009
milten1
  • 1304 Answers
SOURCE: WE have a Hotpoint Microwave mounted over the
yes,
you will need to tzke the unit down
look on the back upper middle
you will see your vent fan
open the cover
pull the fan up
and rotate it 90 degrees, but you will need to install a vent for it
you can also turn it 180 degrees if you on an outside wall and the ven is directly behind the machine
Posted on Oct 26, 2009
  • 8404 Answers
SOURCE: I have a microwave oven of model:17PM-MEC of IFB
A thin layer of???
Is this a clear plastic cover in place to protect the finish? If so, remove it.
Probably best top remove it. Did you check your oven documentation?
Thanks for your interest in FixYa.com
Posted on Dec 11, 2009
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Bulb replacement
Is it an over-the-range (OTR) microwave or a countertop microwave? If it's an OTR microwave, are you talking about the light(s) on the bottom of the microwave, or the one that lights up the cavity when you open the door or run the microwave?
If it's an OTR microwave, and the cavity light is burned out, you MAY be able to access it by removing the grill vent by removing the 2 to 4 screws above it. Then, depending on the model, either slide the grill vent to the left and pull it out, or else pull out the top part of it first. Then, if there is one, you may see an access cover behind the grill vent. Unplug the microwave, then remove the 2 screw that holds the access cover in place, and lift up and remove the cover. You should now be able to get to the light bulb.
If it's a counter-top microwave, you will have to remove the complete cover by removing the screws on the back, and possibly a couple of the sides. Note, 2 screws are special security screws to prevent the casual customer from fixing his own microwave oven! UNPLUG THE MICROWAVE FIRST, then remove the cover screws. Slide the cover back about 1/2 inch, and then it should come completely off. You should now be able to see the light bulb to change it. Then reverse the process to put the cover back on. I hope this helps.
Oct 21, 2014 | Microwave Ovens
My kenmore microwave oven model 721.85033111 vent fan stays on
The contacts in the vent fan relay are probably welded together from all the use over the years. May/may not be able to replace it. Some models have a removable cover, you could try to remove the cover, free the contacts, clean therm with a small file and try it, sometimes it works for a few more years. WARNING: Microwave ovens are very dangerous due to very high voltage inside them. be very careful when servicing the, many people have been killed playing with them!
Aug 10, 2014 | Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
How do you replace intermittent door switch on Hotpoint RVM1335BC001 microwave
Open the Micro door, and remove the air/Vent cover on the top if there is one, Usualy 2 screws on top or the middle of the cover.
Remove the screw holding the Controller board and then you will have access to the door switches 2-3 of them depending on Manif.
Also make sure you have the power unpluged befoe you do any of this.
Oct 27, 2009 | Hotpoint RVM1635 Microwave Oven
WE have a Hotpoint Microwave mounted over the stove and it is not vented to the ouside! It's model #RVM 1435! Can it be vented outside?
yes,
open the cover
pull the fan up
Oct 26, 2009 | Microwave Ovens
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Venting
Click on link to Hotpoint. Instructions ore in pdf.
http://www.hotpoint.com/microwave/index.htm
Oct 27, 2008 | Hotpoint RVM1635 Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
