Question about Sony Cyber-shot DSC-W55 Digital Camera
My LCD Screen is not turning on
Hi, like the tittle says i have this problem: the lights of my LCD don't turn on. The LCD is working fine, the problem is that it doesn't illuminates. I wanna know if there is a simple solution.
  • 49 Answers
There is no SIMPLE solution unfortunately...
its probably not so great that the LCD has no problem as it makes it harder for professionals to fix it as it is probably a circuit problem.
its still worth a shot if you want to spend the money to fix it but its probably easier to just buy a new one.
Posted on Nov 06, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
I turn on the camera and all it shows in the screen is colorful lines and mostly blocks of black. everything else still works on the camera but the screen is not visible at all to see what i am taking a...
You may have damaged your lcd screen. If the screen still lights up the your back light should be fine. You can go to www.thefotogeeks.com for a replacement lcd for your C613.
May 12, 2010 | Kodak EasyShare C613 Digital Camera
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Black LCD screen but Lens view & record fine
It is possible you have turned the LCD screen off - Go to the settings in the camera and reselct the LCD Screen on.
May 11, 2009 | Cameras
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Camera beeps and won't turn on
Try playing with the lense I had the same problem. I would turn it on and the screen was frozen, the three beeps then it turned off. I played with the lense since it was sticking out and I tried turning it on again and it worked. :]
Jul 24, 2008 | Casio Exilim EX-V7 Digital Camera
MY LCD SCREEN DOESN´T WORK GOOD
Hello Emilio, it seems that your camera was in contact with water or Coca-Cola. In order to repair it you should change light guide plate part number: 147913011 or LCD part number: 180572011 or both. Best regards, Arpi
Apr 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
White Screen + Stuck Lens
Turn the camara off and lightly tap on the front about 10 times the white screen will go away just tried it on mine a couple of min ago and it worked. don;t know about lens
Feb 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
