Question about Canon imagePROGRAF IPF605 Printer
Paper not feeding straight
Towards the end of the roll the paper crumples up and does not feed straight
Bowmans IT
  • 85 Answers
SOURCE: Paper Feed Error
Your saying the printer grabs the paper on the one side more than the other?
Posted on Nov 13, 2007
SOURCE: Paper will not feed properly/one side of paper not feeding in straight
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 23, 2008
Touch2Heaven
  • 145 Answers
SOURCE: iP4300 - paper not feeding through to print
clean with special liquid rollers...
Posted on Jan 21, 2009
  • 523 Answers
SOURCE: cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Posted on Mar 11, 2009
  • 739 Answers
SOURCE: Canon Pixma MP470, paper feed not straight
Hi Dave
First thing to check is that the left hand paper guide (as you look at the printer from the front) is up tight against the edge of the paper stack in the feeder. I've seen many printers where (over the course of day to day use) the paper guide has progressively moved itself to the left so that the paper is not held at all. The pick-up for the paper is at the bottom right hand corner and if the guide is loose the paper can skew as it goes in - and then it only gets worse.
Another possibility (and this has just happened to me) is that the long piece of sponge that runs the length of the platen (you'll only see it if you open the top and shine a light in) has come adrift slightly. Mine actually came completely out after 2 or three skewed/crumpled sheets. I washed it, dried it out with kitchen towel and then carefully refitted it. Now the printer is running like a demon.
Let us know what your outcome is.
Posted on Dec 06, 2009
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
    When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
    Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
    Try cleaning the rollers with methylated spirits.
    Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
    The paper won't feed through. it did one minute then stopped
    This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
    Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    Paper gets crumpled and wrinkled and won't feed.
    is printer new i would take it back if u can if not go lexmark.com download ther latest driver ok may fix it up best u can do try feeding paper throw it fe w times train it
    Oct 09, 2008 | Lexmark X2600 InkJet Printer
    Hp laserjet 4650 crumples leading edge of paper
    When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
    Oct 01, 2008 | HP LaserJet 4650 Color Printer
    XEROX 5328
    That is an exit Jam code in the fuser.
    You may just have one of the fingers bent straight down blocking the paper.
    There also may be a secondary code that is causing the E-4-0.
    But that is where to start. Look under the exit web cover for a piece of paper crumpled in that area.
    Once there you may have to remove the fiser web cover to remove that jam and straighten out the finger.
    MAKE SURE IF YOU GO INTO THAT AREA TO UNPLUG THE MACHINE.
    Dec 07, 2007 | Office Equipment & Supplies
    Canon imagePROGRAF IPF605 Printer Logo
    old marine
    old marine
