Question about Ovens
Stoves cooker hood light button flashing when extractor on- why
Filters have been changed but still flashing
2 Suggested Answers
SOURCE: oven light
how to change the light bulb in the oven of the stoves panache 6oosidlm
Posted on Jan 10, 2010
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
No power to cooker hood
Should be on a separate breaker, sometimes wired to a clock/fridge circuit. Check all breakers. I have seen people wire them to a GFCI outlet as well, not supposed to, but people still do it. Check for 120Vac at the fan and light switches, if its ther your switch is bad, it not there cicuit is not connected to power supply.
Aug 25, 2014 | Ovens
I need to change the sponge filter but cannot seem to buy one
go to the place u bought the unit. if that does not exist, then git 2 homie depot,lowes, or sears,who ever. and take u r filter with you. there r replacement filters, or alternatives. lol.
Apr 13, 2014 | Baumatic Ovens
How do i increase the volume on the alarm timer on my stoves cooker
From the handbook:--
Press the MINUS button to listen to the first tone.
Release the MINUS button and press it again to listen to the second tone.
Releasing the MINUS button after the tone has sounded will automatically select that tone.
Jun 14, 2011 | Stoves 720EF Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Do I need a fan for exhauting air from the kitchen when I use a Sunfire gas convection oven?
The oven burns using a gas and oxygen mix , if the room is airtight the oven will go out and you will suffocate.
All cookers should be used in a reasonably well ventilated area which can include extractors and open doors or windows.
This environment gives the cooker enough air to work with and clears cooking smells from the room
Extractors are optional but good ventilation is crucial.
I
Mar 04, 2010 | Ovens
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Oven light
Sep 02, 2007 | Ovens
Ovens Logo
234 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
