Question about Sony KDE-42XS955 42 in. Plasma HDTV
My sony kde-42xs955 error code blinks 9 times
4 Suggested Answers
praky16
  • 744 Answers
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Posted on Apr 10, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: need model name/number for wall mounting bracket for KDE-42XS955
The model # is SUPW3M here is a link to the PDF file with all the info you need.
http://www.docs.sony.com/release/SUPW3M.pdf
Posted on May 17, 2009
  • 608 Answers
SOURCE: I have a SONY BRAVIA
If it does not turn on or turns on and then right back off it is most likely the power board.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 17, 2010
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
Sony Wega Plasma 42XS955. Over 2 wks., gradually
I would check the capicitors on the power supply to see if the they are bulging at the top or leaking. I had a Samsung lcd that starting taking and hour to turn on then eventually it would not turn on. So I checked the power supply and saw four bulging capacitors that I replaced and now it's working like new.
Oct 31, 2013 | Sony Televison & Video
Are there installations recommendations regarding above gas fireplaces?
dont understand the ?, sure there are better units than others and better suited units for someones needs, ex. btu rating, if you want heat bigger btu,
Jan 19, 2010 | Sony KDE-42XS955 42 in. Plasma HDTV
My component cable is not showing any video.
it is a a/v hook up not a component hook up
try that like av1 av2 av3
should work a lot better
ron
Aug 29, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Sound but no picture
try this simple test i know its kinda weird, but it helps to know what seems to be the problem.tap your unit three times, while tapping look at the screen, see if it flicker or the screen has picture.then, check all connection, if its all ok. then, you'll need a tech to do a manual troubleshooting.
May 18, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Small vertical stripe about 6" from left side
go to the settings menu and try to reset the screen position...
Apr 02, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Power
today i did repaired same problem same tv.
cold solders on powersupply board. resolder all cracks!
Aug 26, 2008 | Sony KDE-42XS955 42 in. Plasma HDTV
Sony KDE-42XS955 42 in. Plasma HDTV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
