Question about OKI B Office Equipment & Supplies
Error code 001B - B OKI Office Equipment & Supplies
I have a toner bar out and cannot get it back in and the 001B code came up... any ideas on where I can go with this now?
Posted on Mar 30, 2013
2 Suggested Answers
SOURCE: i have an error code 001B on my 1690mf can any
Yes I have had this exact same problem.
It makes a thumping (louder) sound when turning off and on the Machine too. This is caused by not putting in the toner 100% in. If you want to get the toner securely in, try pressing (trying not to touch the toner bars) the toner cartridges in as much as you can from the front panel, and top panel (taking out the top imaging peice first to access the toners).
Posted on Apr 07, 2011
How do i remove toner manually in a a oki mc160. I am getting a service call 001b error
Error 001b means the dev motor cannot turn. The most common problem on this extremely complicated system is that a toner has not been locked correctly and has come loose thus jamming the drum and preventing it from turning. The easiest way to resolve this is to remove the front cover which will give access to the drum mechanism. You hopefully may be able to then push the unlocked toner back into place. This type of printer is a pain when it goes wrong. Have not seen one in years even though only came out in 2009. Good luck.
Mar 09, 2017 | OKI Office Equipment & Supplies
Tip
VAG COM Fault Codes
ERROR CODE (DECIMAL) - CODE ERROR - ERROR CODE (OBD II) -The description ERRORS
00000 0000 O End
00001 0001 braking system control unit
00002 0002 gearbox control unit
00003 0003 control unit
00004 0004 control unit for engine gas-J659
00016 0010 Vers. electric space heater, rear right damper leg / defroster-V195
00017 0011 Vers. electric space heater, rear left footwell flap / defroster-V196
00018 0012 Executive electric cold air flap-V197
00019 0013 Executive damper motor warm air-V198
00020 0014 Executive electric Right flap and defroster vent-V199
00021 0015 Executive electric left flap and defroster vent-V200
00022 0016 Executive electric right hot air flap at the rear of the center console-V201
00023 0017 Executive electric left hot air flap at the rear of the center console-V202
00024 0018 Executive electric right cold air flap at the rear of the center console-V203
00025 0019 Executive electric left cold air flap at the rear of the center console-V204
00026 Executive 001A motor Right flap and defroster vent-V205
00027 Executive 001B motor left flap and defroster vent-V206
00028 001C Executive electric left bezel-V207
00029 001D Executive electric central bezel-V208
00030 Executive 001E motor right bezel-V209
00031 001F defrost key left rear glass-E299
00032 0020 defrost button the right rear window-E300
00033 0021 Control button front left deflector-E301
00034 0022 Control button front left center vent-E302
00035 0023 Control button front right center vent-E303
00036 0024 Control button right front baffle-E304
00037 0025 Key for adjustment of the temperature difference between the space for the legs and the upper part of the cabin-E305
00038 0026 Control button left rear deflector in the center console-E306
00039 0027 Control button right rear deflector in the center console-E307
00040 0028 lock button door opener inside-E318
00041 0029 Executive damper motor uniform air flow-V213
00042 Lamp 002A left hand fire-M43
00043 002B lamp right hand fire-M44
00044 002C Perform test 1 group of actuators
00045 002D Check Now 2 groups of actuators
00046 002E Electric retractable washer jets left headlight-V248
00047 002F motor sliding washer jets right headlight-V249
00048 0030 heat exchanger temperature sensor, left-G306
00049 0031 heat exchanger temperature sensor, right-G307
00050 0032 temperature sensor-G308 Evaporator
Full list of fault codes here
Car Manuals PDF
on Dec 20, 2016 | Cars & Trucks
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
Sep 12, 2013 | Audio Players & Recorders
Konica Minolta magicolor 1680MF error 001b
Hi)
I had some interesting solution for 001b error:
there was incorrectly installed, not clicked in self seated place, and I've just clicked it to one's place - I only need to push the big Transfer block out ))
May 22, 2012 | Konica Minolta magicolor 1680MF -...
Km1690 call for service 001b
Sorry to hear about your 1690... but the error you're seeing is a pretty common one, so you definitely aren't alone.
The first step is rebooting the machine. Usually this clears the error, and you can resume normal operation. If that doesn't fix it you will need to obtain service. My experience dictates that the code you're seeing could mean a couple different things. I have seen this stem from a drum malfunction (pretty basic) to a mainboard failure (very serious). The only way to know for sure is to have a technician look at it and run appropriate diagnostics.
Nov 21, 2011 | Computers & Internet
I have an error code 001B on my 1690mf can any help?
Mar 09, 2011 | Konica Minolta magicolor 1690MF All-In-One...
I have been using Micrografx Designer 3.1 in Windows XP for several years now. Recently, however, I have discovered that I cannot add text to a drawing. When I attempt to do so, I get the following error...
please save all your projectx and try re installing the programme...
if problem still persist then re install your system... yhe problem seems tobe with corrupted registry file
Feb 23, 2011 | Computers & Internet
Fix the fatal error in my warcraft 3 frozen throne
This application has encounter a critical error:
FATAL ERROR!
Program: F:\games\lan games\warcraft 1.24.1.6374\war3.exe Exception 0xC0000005(ACCESS_VIOLATION) at 001B:15019B9E
The instruction at '0x15019B9E' referenced at '0x57746E65' Ther memory could not be 'read'
Press OK to terminate application.
Then:
Frozen Throne was unable to locate your CD-ROM drive. Please make sure your Frozen Throne disc is in your CD-ROM drive, then click on 'Retry'.
Oct 22, 2009 | Blizzard Entertainment WarCraft III: The...
573 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
