Question about Toshiba TEC B-472 Thermal Label Printer
How to adjust print head temperature on TEC B-452-HS12-QQ
In troubleshooting it makes reference to "turn down print head temperature", but it says no where HOW to turn down print head temperature. We have a model B-452-HS12-QQ
Thanks, Mike
  • Anonymous Feb 25, 2009
    Printing is not ok. It is blurr
  • 19 Answers
It depends if you are working with driver, label software or escape commands. If you are working with escapes you can try with command AY, refer to the programming manual.
If you are working with Seagull driver you can adjust the print density in OPTIONS
Posted on Feb 10, 2009
How do i clean the printhead on toshiba B452?
Try alcohol and a soft cloth or cotton.
But I'm afraid you'll have to change the print head.
Feb 20, 2014 | Toshiba TEC B-452 Thermal Label Printer
Tec b-452 barcode not clear
change the heat value and the speed value or you may have the wrong ribbon
Feb 15, 2014 | Toshiba TEC B-452 Thermal Label Printer
Tec 452 printkop
Check the fonts used.
Probably a driver problem
Feb 01, 2014 | Toshiba TEC B-452 Thermal Label Printer
Does anyone know how to rectify the TEC B-SX4 head temperature error? it's the correct version printhead for the model of MLB and the correct firmware, but problem still exists.
This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
Oct 23, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Tec B 452 error 482 run time error, printer error
This is a problem with windows error 482 is probably a problem with activeX
Jan 04, 2012 | Toshiba TEC B-452 Thermal Label Printer
TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Nov 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
May 18, 2008 | Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
911 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
