Question about HP LaserJet 4650n Printer
Hp 4650 n - New Fuser Kit
I just installed a new fuser kit, and it works, but I am still getting the message that I only have a few copies to go. I never got the "new fuser kit" message so that I could reset the fuser count.
  • 2 more comments
  • ryderj Oct 28, 2008
    We have about 150,000 copies on this printer, and have changed toner cartridges frequently. This is definitely the fuser kit. The message says "ORDER FUSER KIT Less than 1400 pages". So I ordered the correct fuser for the 110v use that I have, then installed it - very easy to do. The instruction book, at Step #7 says: "Close the top cover. Turn the printer on. After a short while, the control panel should display NEW FUSER KIT=" Step #8 then leads you to reset the fuser count.
    I never got the "NEW FUSER KIT=" message, and cannot find fuser count in any of the settings.
  • finkie1 Jan 12, 2009
    I have the same problem. I received the "order fuser kit" msg and ordered and replaced the fuser.
    However, the msg is still there but the number of pages has changed that are left.
  • Frank
    Frank May 11, 2010
    did the message tells you it is the fuser???
    usually the message is for toner.
  • Anonymous Mar 13, 2014
    reset fuser count that wasn't displaying an error
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Posted on May 05, 2009
You can reset the counter in het service menu.
Posted on Mar 07, 2009
    Genius:
  • 1,605 Answers
My sugestion is to reinstall the fuser. make sure all contact are clean.
Posted on Oct 28, 2008
Hp cm4540 fuser kit counter reset
allot of the newer HP printers can not be reset they have a fuse in the new fuser when it is installed it blows the fuse in the new fuser & resets the count.
Aug 01, 2012 | HEWLETT-PACKARD CM4540 AllInOne Laser...
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
To reset fuser status, on the printer:
1. Press the "Menu" button
2. Navigate to "Configure Device"
3. Select "Reset Supplies"
3. Select "New Fuser Kit"
After doing so, the printer will reset the count on the fuser.
May 09, 2011 | HP LaserJet 5550 Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Need to change out a fuser kit
1. Turn the printer off.
2. Open the top cover.
3. Grasp the purple handles on the fuser.
4. Remove the old fuser from the printer.
5. Install the new fuser.
6. Close the top cover.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00366229/c00366229.pdf
Mar 20, 2009 | HP LaserJet 4700 Printer
I have just fitted a new image fuser kit to our HP 4650 laser printer. However, the error message "replace fuser kit" reappeared on switching the printer back on. Any ideas. Have taken it out...
To reset the fuser count, do the following:
1 Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight RESETS.
5 Press to select RESETS.
6 Press to highlight RESET SUPPLIES.
7 Press to select RESET SUPPLIES.
8 Press to highlight NEW FUSER KIT.
9 Press to select NEW FUSER KIT.
10 Press to highlight YES.
11 Press to reset the fuser count.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | HP Computers & Internet
HELP! 3 year old HP color Laserjet 3500 Installed first fuser kit...error message 50.2 fuser is hot message. Worked through directions; same message appears repeatedly.
The connecter between Fuser and printer is not connected properly. Reset the fuser.
To remove the fuer fuser and measur resistance between the fuser connectors J50132A-2(mainth)and J50132A-1 (gnd) if it is not within the range of 330k ohms TO 50k ohms at (abient temp) Replace the fuser.
Oct 08, 2008 | HP Computers & Internet
HP LaserJet 4650n Printer Logo
1,229 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
