Question about Cerwin Vega Audio Players & Recorders
Cerwin vega crossover repair AT-100
My speakers sound different from one another. one of them is not as bassy as the other one . ive swapped the woofers around with the speaker boxes , and to my surprise the woofer with the other speaker box which wasnt as bassy became very bassy as it shud be. and the other woofer which was very bassy in the other speaker box lost some of it bass. theres actually something wrong in one of the crossovers. could you help with this , i want to try and check them and repair them my self . thanks mr d
3 Suggested Answers
  • 3 Answers
SOURCE: i have a set of cerwin vega ls-12 3way woofer works but tweeters
There is an old cheap way to test any speaker. If you have a multi-meter, set it on OHMS. Then, while holding one lead against one speaker terminal, tap the other meter lead to the other speaker terminal. If the speaker is good, you will hear faint crackles. If you do not have a meter do not despair, you can do the same test using an AA or AAA battery with leads held to the battery.
Good luck! P.S. Nice speakers.
Posted on May 22, 2009
thanks for replying so fast "oilcitycompu", i will do that .will let you know if it worked , thanks
Posted on May 23, 2009
I want to replace the capacitors on my Cerwin vega D5 speakers but have never done it before. I could help with parts and procedures. Thank you for your time, Rob
Well it is not an easy task to tweak crossover.If you just change capacitors,it could bring some advantages put probably will bring in the same time more unpleasant sound.If the old capacitor is MKT one then the new one should be MKT as well - if not you might get some frequences very loud and so unpleasant sound.MKP capacitoprs have very low resistance but mind the fact that the whole crossover was projected to use MKT capacitors.The same is for bas area - change electrolityc c with the same type but of good quolity - Mundorf maybe
Apr 07, 2016 | Cerwin Vega Audio Players & Recorders
I own a CERWIN-VEGA V-12S 12" Front Firing V
You may have only messed up the crossover circuit. Try changing the crossover frequency and see if hte behavior changes. If so, then the parts cost should be minimal. If the behaviorr remains the same, there will need to be more investigation done internally. This is not a problem that is likely to be easily resolved remotely. Can you update this with your location? I may be able to provide a recommendation for a service shop.
Jan 05, 2011 | Cerwin Vega V-10S Subwoofer
Cerwin Vega do I connect
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
No sound coming out of speakers on my cerwin vega
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
Only voice from tweeter is coming, nothing from the mid-range and woofers. on cerwin vega v10f
Well it's a good thing that you are getting sound from the tweeter from the speaker cabinet with the problem, that eliminates one of the possible problems; your wires are connected!
If your other speaker sounds fine, the first thing to try is to swap your speaker wires with the one that sounds fine. If the problem speaker cabinet still only produces sound from the tweeter, the problem is within the speaker. If the problem goes away, the problem is from your electronics.
If the problem is within your speaker and it is still under warranty, find a authorized repair location (
Problems within the speaker can only be one or more of the following: 1) The drivers not producing sound have been blown; played with either too much power and/or distortion. Distortion is created when you play your music too loud with a amp not able to reproduce what you are looking for in sound, the speaker itself can hear it before you can.
2) The speaker cabinet has a crossover inside which directs the proper sounds to the proper driver. This crossover can have components that have been broken be either #1 or from exsessive vibration.
3) There are wires inside of the speaker cabinet that have been disconnected. This can happen over time or if someone reaches inside of the cabinet through the port and pulls on the wires; like a young child or pet such as cats.
If the drivers in question just one day stopped producing sound, start with the easiest solution, #3 then #1 if you can suspect anyone could have played your speakers other than you.
To diagnose the problem, you first start by removing the woofer and confirm that all of the wires are connected and in good condition. While the woofer is removed, to eliminate that there is a problem with the speakers, temporarily connect the mid-range and woofer, one at a time, directly to the wire coming from your electontics, if they produce sound the problem is within the crossover network, if they do not produce sound, the problem is with the driver itself. Replacement parts should only be purchased directly from Cerwin Vega directly (
Jan 25, 2010 | Cerwin Vega Cerwin-Vega V-10F Floor...
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service:
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cerwin Vega D9-E Speakers. Bad crossovers...I think. Fixable?
Crossovers are made with wire coils, electrolytic capacitors and resistors.
Capacitors may get leaky or blown with time and heavy use, and are quite easy to find, just be sure to use the same polarity, capacity and voltage rating and to respect the polarity if it's a polarized capacitor.
There may also be a burnt out resistor or a coil. Resistors can be obtained and replaced (same resistance and wattage) and wire coils can be rewound (same amount of wire of the same wire gauge).
Another possibility is a partially damaged wire on the speaker itself. This is the braided curl wire that goes from the speaker membrane to the cable connection lugs on the speaker armature, and it may be damaged at the membrane side or the lug side.
It usually happens from what you call "overcooking".
To repair this it will require some soldering skills, but it's a bit hard to solder that type of wire, as it tends to oxydize and is difficult to clean prior to soldering, it may be difficult to access it, depending on the speaker structure(an alternative to this is to replace the speaker itself).
There may be some physical damage to the membranes if the sound is present but is of a bad quality (a slightly damaged membrane may be repaired using some rubber glue, but it will never return the speaker to the original condition).
These are just some suggestions, hope they can help you get closer to a solution.
3rq8 (triarcuate)
Jul 23, 2009 | Cerwin Vega CLS-12 Main / Stereo Speaker
Top Cerwin Vega Audio Players & Recorders Experts
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
