Question about Jenn-Air JDB6510 Built-in Dishwasher
Jenn air model JDB6510AWP will not pump out water
I opened the door and the bottom was full of water.
SOURCE: Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Posted on Aug 12, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
lsteward68
  • 331 Answers
SOURCE: My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Posted on Apr 27, 2009
SOURCE: Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Posted on Jun 13, 2009
aasc
  • 1606 Answers
SOURCE: Water collecting in freezer bottom
Remove the 2 screws which hold the lower panel inside the freezer and remove the panel .Use a hairdryer and defrost the lower part where the drain is . I use a small hose to blow thru the drain hole to remove any debris which will build up after time . Then useing a 14-16 guage aluminum wire (remove the insulation first), insert it into the drain hole without any pressure , until it stops ( pour water thru the drain first , to make sure it is open ) and wrap the top end of the wire around the calrod heater (the black rod just above the drain hole) about 1 turn . When the refrig goes into defrost , the heater will transfer heat to the wire and keep the drain hole from freezing up again .
Posted on Aug 02, 2009
I have a Jenn-Air side by side refrigerator. It has built up ice in the very bottom about three inches thick. What could be the problem?
ice is water freezing so check where the water is getting in ( leaking water bottles being frozen, bad door seals, too frequent door opening etc
Jul 10, 2016 | Jenn-Air Refrigerators
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
We have a jenn-air jfc2087hrs (french door model) and the water pressure from the internal water dispenser is very low. the line has plenty of pressure.
If your ice maker is making full size cubes then it should one of 2 problems.
The water valve on the bottom back of the machine is a dual valve. One side feeds the ice maker, the other side feeds the water supply.
1. The dual water valve. is going bad. The water side is malfunctioning.
The dual valve must be replaced.
2. Your model should have filters for the water dispenser, and need replaced.
Try changing the filters first.
Oct 04, 2009 | Jenn-Air JFC2087HRS Side by Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
Water enters dishwasher, soap door opens but soap
That's a normal path for the soap. It sounds like the water just sits in the bottom without being pumped through the spray arms. Does the pump motor run? Pop the door open in the middle of the washing cycle--you should see hot water dripping from everything and the soap picked up and circulated with the water. If this machine has seen a lot of use, the intake screen under the lower spray arm may be plugged and is accessed by removing the spray arm and working your way down to the bottom of the deck. Might be a problem for a service technician to take care of.
Jul 19, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Broke Glass door for Jenn-Air 701642K
Hi, Go to www.bellparts.com and tyoe in the model # located on a tag either around the door opening or around the bottom drawer.
I hope this helps you.
Vic
Jul 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JDB6510 Built-in Dishwasher Logo
29 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
