Question about Dryers
Kenmore dryer 96585210
Dryer does not give off heat
5 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: Kenmore dryer doesn't give off heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 97 Answers
SOURCE: model 96585210 ss mf1636458
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 11, 2010
  • 220 Answers
SOURCE: i have a kenmore dryer
The Heating Element went out and needs immediate attention. A simple replacing of the heating element will fix your issue. 10-15 minute job.
Posted on Apr 18, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My kemore (Model Number 96585210) runs for about 5 min then shuts off and will not start again for about 30 min.
hope this helps, usually when it shuts down like that it is because it is overheating. make sure that the venting system is totally clear of and build-up. hope it is as easy as this. it usually is. if you had a big problem with your dryer it would most likely not work at all. good luck ! post your results please. Tim
Sep 16, 2012 | Kenmore Dryers
I have a kenmore dryer model 96585210 it wont heat up
Apr 18, 2011 | Dryers
My kenmore dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details...
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
heatman101
Nov 13, 2010 | Kenmore Dryers
Kenmore 80 series dryer starts(runs) but will not give off any heat?
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 07, 2010 | Kenmore 65924 Electric Dryer
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops...
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Oct 02, 2010 | Kenmore Dryers
Kenmore Gas Clothes Dryer does not heat sufficiently
Ok, first and foremost, make sure your vent is clean and clear.
If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
Jun 27, 2010 | Kenmore 63942 Dryer
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Model 96585210 ss mf1636458 dryer will not heat, how to fix
Jun 16, 2009 | Kenmore 63942 Dryer
Dryer spins does not heat up
I CAN GIVE YOU THE ANSWER TO YOUR TROUBLES. THE HEATING ELEMENT IN YOUR DRYER IS GONE. CALL A REPAIRMAN AND SEE HOW MUCH IT WILL COST TO GET YA A NEW HEATING ELEMENT INSTALLED.
RODNEY
May 16, 2009 | Kenmore 64812 Electric Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
