Question about Toshiba Televison & Video
Toshiba 37bv700b won't turn on. blue stanby light flashing
Tv not turning on/responding to remote . Have changed batteries and turned tv off at the wall. blue standby light slowly flashing
  • 163 Answers
SOURCE: Remote does not seem to be communicating with TV.
I presume you have replaced the batteries in the remote control and had it checked to confirm it is working if so the most likely cause of faliure to come out of stand by is a currupted eprom (memory chip) within the TV and will require a technician to replace or reprogram
SUPER8
Posted on Nov 13, 2008
  • 225 Answers
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Posted on Nov 14, 2008
shbuckler
  • 126 Answers
SOURCE: tv wont turn on standby light flashing
seems like an error code (the flashing)
I would say if there is an error code it need to be taken for repair
Posted on Dec 25, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
  • 979 Answers
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Posted on Apr 15, 2010
Testimonial: "how helpfull thanku kindly !"
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Audio Players & Recorders
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
Acoustic Solutions LCD26761HDF TV turned itself off & standby light started flashing. TV wont respond to remote or on set buttons
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Sep 25, 2010 | Daewoo DLP3212 32 in. LCD Television
Tv slowly started to not respond to remote control. now it does nothing and we have to manually turn channels. i have tried every code to reprogram the universal remote, and nothing works.
I don't intend to be a smart *** but, have you changed the batteries?
The "slowly started to not respond" is a key indicator of dead batteries in a remote.
Mar 20, 2010 | Televison & Video
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
306 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
