Question about Toshiba 32A32 32" TV
Menu keep popping up
Hi my menu display keeps popping up by its self and it will not go away it acts like the menu button is getting pushed. the checked the board for any burnt pins and checked for a stuck button but still no luck. pls help
The button is shorted, unsolder the button and take it out. you can use the remote to use the menu if you want, you can also buy a new switch from radio shack.
Posted on Oct 26, 2010
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Feb 21, 2011 | Acer XD1150 DLP Projector
I have a seaco royal coffee machine and it keep telling me to fill water tank when its full. what can i do
Hi
Go into the menu.
Scroll with the arrows on the panel until you get to "Direct Water Connection".
Push the menu button, and chose "OFF", then push the menu button again, then esc. button twice and it should go away.
Dec 04, 2010 | Saeco Royal Professional Espresso Machine
Brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Nov 19, 2010 | Brother Office Equipment & Supplies
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
I keep getting the OSD LOCKED that keeps popping up on my screen and it flashes on top of my page and is driving me nuts how do i get it to stop
Are you holding the menu button down when the monitor is off or on? Are you keeping the menu button held down when you push the power button to turn it on?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748106&cc=us&lc=en&dlc=en&product=3194521#N57...vv
May 18, 2010 | HP Compaq dc7100 PC Desktop
Can't watch dvds/Main menu won't pop up
hi need the cd for eclipse avn50d so it can work how can i get it?
Dec 17, 2009 | Lanzar SD31TD Car DVD Player
Menu keeps popping up on screen on 52 r5wh73
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Also double check that the remote is not the problem by removing it from the room or removing the batteries
Let me know if you need more help or info.
Dec 03, 2009 | RCA R52WH73 Projection Television
Osd menu keeps popping up
tv is in store display mode. sorry dont rember how to turn off owners man will say.
Nov 30, 2008 | Apex Digital AT2008S 20" TV
Menu pop ups
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Apr 13, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Toshiba 32A32 32" TV Logo
427 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
