Question about Bush Televison & Video
Bush bdvd 7298m
Hi, i purchased the portable dvd player 14months ago and have used it twice. the main unit is no longer ready that a disc is inserted. please help.
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: I have a twin portable
how long have you been using this player? The problem should be from the lens (laser) of the other part of the player.
The lens is weak and that's why it cannot read/load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Posted on Dec 06, 2010
SOURCE: bush bdvd 8380 any ideas? thanks
i have a bush dvd8380 player when i put it on charging green light blinks nd it does not come on so how will i fix it
Posted on Dec 08, 2011
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
Unblock region code block for Bush BDVD 8310
Hi
You have to flick the on/off switch (which is on the side next to the volume control) towards the back of the machine then it charges. The switch has 3 operations.... towards the front is on, in the middle is off and towards the back is charge...
Aug 16, 2011 | Televison & Video
Hi there, I purchased a Bush lcd/ dvd combi for my daughter 18 months ago.... All of a sudden it is not reading the dvds and automatically ejecting them, any ideas on what the problem is, and how possibly...
Hello
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
May 30, 2011 | Bush DVD142RC 14 in. TV/DVD Combo
Hi my portable dvd player by insignia won't read
Try using a lens cleaner. Also, reset the unit to factory defaults. Ensure that the disk you are attempting to play is clean and scratch-free. If the problem persists, you may pursue service options through the place of purchase.
Jun 20, 2010 | Insignia NS-PDVD10 Portable DVD Player
Bush bdvd 8380 any ideas? thanks
Aug 18, 2009 | Bush Televison & Video
Main screen has no picture
go to you`r pics and change wich pic you want.
Jun 27, 2009 | Durabrand DUR7 Portable DVD Player
Durabrand portable dvd player dur-7
Duarbrand portable DVD players are no longer supported by Walmart because the company contracted to manufacture them is no longer in business. Ripoffreport.com has several complaints on the product line. Walmart has been exchanging the item.
Jun 28, 2008 | Durabrand DUR7 Portable DVD Player
Dvd stutter
Hi lynnjunell,
I regret to hear you are having trouble with the Insignia® DVD player you purchased.
It is possible that the problem is with the DVD, even if it plays in other units. I would recommend first clean the DVD carefully to remove any residue or debris that may be on the disc. If this is still happening on multiple discs and cleaning does not help, I would recommend brining in the unit to your local Best Buy™ store to be checked out by the Geek Squad® precinct. If you are unable to locate your sales slip, the store may be able to assist if you recall some specific information surrounding the purchase. You may also call 1-888-BEST BUY (1-888-237-8287) for assistance in locating your purchase information for warranty purposes.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 17, 2008 | Insignia PD10135 Portable DVD Player
Portable DVDs
Salutations jwatts325,
There are specific models that have auxillary monitors that will be powered from the main unit. Unfortunately if its not configured with an auxiliary unit there isn't a way to chain two portable units together.
Sorry I couldn't be of more help.
Jon
Go Ahead. Use Us.
May 21, 2008 | Televison & Video
Bush recorder no longer finds blank dvd
Owing to the fact that it works with the original discs, the set is probably ok. BUT it's not very compatible with the blank discs you've purchased. You'll have to experiment with various brands until you find those that work. I find my Cyberhome deck is not only particular with some brands, but with different batches of the same brand disc. Ask some of the big box stores that sell blanks and you'll find they get a lot of returns for the same reason, they don't work in the customer's machine. Bush doesn't sound very competent in the customer support dept, so I would look to replace your Bush recorder with something more main line, and probably more expensive and compatible.
Oh, and make sure you are getting the same type of disc- DVD-R and DVD+R are not the same.
Feb 17, 2008 | Televison & Video
Televison & Video Logo
111 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
