Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Can print iron on transfer paper on canon PIXMA MP250
  • 153 Answers
SOURCE: Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Posted on Apr 14, 2009
  • 16 Answers
SOURCE: MY PRINTER
in the small moniter what the errore you have like E5 - E2- E3 so that we can help you this Errore know you the problem on the printer
Posted on Dec 02, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma mp250 only prints blank pages
Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
pineworks
  • 4041 Answers
SOURCE: my canon pixma ip2000 will not print. The paper
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Mar 15, 2010
puertobori
  • 7733 Answers
SOURCE: Canon Pixma MP250 with error E3. Computer says
Look on Canon U.S.A. : Support & Drivers : Consumer & Home Office
Posted on Oct 24, 2010
My Canon PIXMA MP250 Inkjet isnt working?
Does the printer power up?If not,check the power cable or probably replace it.
If it does power up,disconnect everything including the usb connections and also turn off your PC.
Wait a while and then re-connect them all.Start the PC first and then turn on the printer.
Now try printing.If still cant print:-
  • You might have run out of ink.Check the cartridges and replace any dry ones.
  • Check for paper jams on the paper paths and manually remove any stuck papers.
Hope this helps.Thanks!
Oct 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon Pixma MP250 with error E3. Computer says there is a paper jam, but I don't see any stuck paper.
saya ada kesulitan tentang masalah printer cannon mp 258, catride tidak bisa ke tengah, selalu ada di tempat pembersih catride dan keluar pesan E03, bagaimana cara nya ?
Oct 23, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
CANON PIXMA MP250 UBUNTU 9.04+ CONNECTION
Canon Inc. made available (finally!) official drivers: 1) for printing cnijfilter-mp250series (v3.20-1) and cnijfilter-common (v3.20-1); 2) for scanning scangearmp-common (v1.40-1) and scangearmp-mp250series (v1.40-1). You can download their from http://support-au.canon.com.au/P/sea..._os&g_os=Linux
also don't forget that manuals will be useful: http://support-au.canon.com.au/P/sea...=0&menu=Manual
Reference http://ubuntuforums.org/showthread.php?t=1314209
Aug 02, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
112 people viewed this question
old marine
old marine
